Will this Pallet Fork work?
   / Will this Pallet Fork work? #1
robertwhite
Will this set of John Deere pallet forks with whatever type of QA it has work with my Bobcat CT335 QA plate and lock on?
Seller says it will work with skid steer and I believe the CT335 uses the same plate as the skid steer.
Don't know why it was a tiny pic.
   / Will this Pallet Fork work? #3
JD tractors use some funky proprietary JD hookup.
unless it was for a john deere skid steer in which case it should have a standard skidsteer attachment.
   / Will this Pallet Fork work? #4
Not all of them, some use the standard SSQA.
   / Will this Pallet Fork work? #5
yes, this is true. The 4x20 series offers SSQA on their FEL, i think it is an option for the 300cx. it will fit your bobcat if it has SSQA.
   / Will this Pallet Fork work? #6
And the "funky" Deere system is lighter in weight than the optional SSQA. :)
I'll opt for less weight in the steel hanging on the FEL so I can increase the load capacity, anyday.
   / Will this Pallet Fork work? #7
What are we talking, 50 to 75 pounds difference? I would rather have something that all types of attachments would work with than some one off thing.
That what made the 3 point hitch so popular. Before that each manufacture had its own special way of hooking up implements and if you wanted to change brands you were screwed in most cases.
Chris
So I gather I need to get another picture showing the attachment points, yes?
   / Will this Pallet Fork work? #9
I think a picture of the back a little larger would help. But if you own a welder and a 4 1/2 grinder I would say you could make them fit.
   / Will this Pallet Fork work? #10
yes another picture, but it should work with the regular type hock up but not if it has the JD specific.
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
Unused 2025 CFG QNT50R Mini Excavator (A49461)
Unused 2025 CFG...
1984 Ford F-Series Flatbed Truck - Classic Workhorse Selling Absolute (A51039)
1984 Ford F-Series...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
