Mowing SQ480 PTO shaft
   / SQ480 PTO shaft #1
birdbert
New Holland TC25
I have a (new to me) Bush Hog Squealer 480-2 with a seized up pto shaft. It will not extend...at least so far.
For 5-8 years, the equipment has been stored outside with the tractor end of the power shaft higher than the mower gear box.
How do I go about loosening the shaft? I am concerned about braking the plastic safety guard which rotates just fine.
Birdbert
   / SQ480 PTO shaft #2
Birdbert
I'd tale the plastic off If I can. Raise the end of the shaft up and keep it up by a string tied up to the end coupler and attached on a rafter or so. I'd spray penetrating oil on the shaft to see if it soaks in. I'll give it some time. Just to encourage things, I take a heat gun and heat up the shaft. I take a hammer and try to jar it a bit and hopefully it comes out. Can put a come along on the tip to see if you can pull the shaft out as the last resort.
JC,
1838 (A51248)
1838 (A51248)
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53473)
2000 Kenworth W900...
2003 Ford F-550 4x4 Terex TL38P 38FT Bucket Truck (A51692)
2003 Ford F-550...
