Locust trees sprayed with 2,4d question
   / Locust trees sprayed with 2,4d question #11
The link I posted above notes mixing of 2-4D with Remedy (triclopyr) for foilage treatment of woody plants. I'll not post the rate as I might incur a typo
   / Locust trees sprayed with 2,4d question #12
My biggest problem is that its pretty hard to coat stump because the are less less than size of a quarter (and most are more like a dime size)..
I use a small paint brush - mixed with diesel in a jar. (how large of an area or how many trees are we talking about again???)
I do have another bottle of week killer that has Triclopyr as the main ingredient.. I will mix some of that up and spray them again..
If the plants are brown like you said... I would wait and treat the re-growth. You *might* get by with a basal stem treatment, but I would not do it - you might be wasting time and chemical.
thanks.. Due to work commitments I havent gotten a chance to read that yet, but Ill do it today..
b
   / Locust trees sprayed with 2,4d question #14
Martins CLEAR PASTURE. Active ingredient is Triclopyr. Clear pasture is a generic of the comparable DOW product for half the price. Is made in Pasadena, Texas. It works greats.
Also check out BRUSH BUSTERS Program on internet. Tells you how to get rid of most problem plants. Info is provided by Mr. McGinty of Texas A&M.
I sorta/kinda think I found it, but I dont know what percentage the mix they are using is.. So I will just mix it per instructions for each..
BUT, Can i safely mix the two weed killers together in the same sprayer without blowing myself up or having something bad happen??
brian
   / Locust trees sprayed with 2,4d question #16
I have spent the last 20 plus years as a rangeland and brush control person full time so perhaps I can help you out with your question.
The locusts could be honey locust or black locust. The Honey Locusts have the gigantic thorns when more mature, Black have small one tip thorns only.
2,4-D will not kill the plants. At best you will see brown out and have the impression of success. But next spring they will be back, and if blacks, they will come back with a vengeance since they reproduce from seed as well as from root buds.
There are some excellent homeowner materials that will kill locusts. But there are a couple tricks to employ if you want to be successful.
First is timing. In your neck of the woods, locusts will be most easily killed with a foliar application in mid July on through the end of August. Spraying earlier will provide mixed results to no results.
Look for products containing triclopyr. That is the active ingredient in Crossbow, Remedy, Garlon. For homeowners its easy to use, will not hurt grass and will kill locusts.
If you choose to cut the trees, treat the cut stump with Tordon RTU. Roundup as a cut stump treatment is very unpredictable and on locust is really not worth your time or effort.
there are other methods that I use in my commercial spray business but this is probably the best option for your situation.
Good luck and stay after them, they are a persistant invader.
Great post Wooddust, welcome to the forum. Information, especially with brush control is so regional, do you mind sharing what part of the country your expertise is in?
We are about to have 68 acres of timber cut and are looking at brush control methods for the next few of years. Mostly pine in our area with a lot of what we call "privet" growing after a cut. It is an invasive species here. Any suggestions?
MarkV
BTW - after looking closer at some mature trees, these are Black Locust..
brian
   / Locust trees sprayed with 2,4d question #18
Can i safely mix the Gordons Brush no more (2,4D, 2,4DP-p, and Dicamba) and the Ortho Chickweed Killer (Triclopyr) together in the same 1 gallon sprayer?
I was using 6oz/gal for the Gordons (it could be mixed anywhere from 2 to 8 oz per gal - per instructions) and the Ortho is 1oz/gal of water
brian
Brian, thats a tough one not knowing how much triclopyr is in the chickweed poop. If you can do the math, IF we were using Remedy that has 4 pounds of triclopyr per gallon, we would mix it at a 2% dilution in water. In other words 98 gals of water would have 2 gal Remedy....now, try to come up with the mix that resembles that or go to the local farm store and buy a quart of crossbow.
   / Locust trees sprayed with 2,4d question #19
MarkV
MOst of my work was done in the midwest and west from Missouri to the west coast. But I have a ton of additional experience and work that I still do in a research capacity. I may not have the answer at my fingertips but probably can steer you in the right direction.
Privet is a bear. Auburn University is recommending basal treatments with Remedy. 20-25% Remedy in 75-80% Diesel. You will love this...you spray the lower stem from ground up 12-15 inches. Its deadly effective but if you have a lot of privet, thats a lot of work. The good news is you can do it 12 months a year. Basal has the added benefit of not hurting other plants in the area.
Roundup can be uses but its 3% or 3 gallons per hundred foliar only applied only in winter. Plus it will smoke other plants and can hurt conifers even foliar in winter.
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 MACK  CXU613T (A58214)
2017 MACK CXU613T...
2014 Toro Groundsmaster 4500D 5- Deck 4WD Rotary Commercial Mower (A56857)
2014 Toro...
