King Kutter XB rotary cutter part?
   / King Kutter XB rotary cutter part? #1
Wacky
West Virginia
2010 GC2610
I need to know if I could buy the "bell" that goes on the pto shaft by the gearbox. Mine caught the shear pin and ripped off the first time I used it. It looks like I could remove the screws on the flange and replace just the bell. I cannot find just a part number to order. All help is greatly appreciated.
   / King Kutter XB rotary cutter part? #2
try King Kutter Incorporated
Get an account on there and you can order the parts online. :thumbsup:
hope this helps. :)
I checked there, but it looks like you can only get it with the complete shaft. I will call them tomarrow and check to see if I can order one. Thanks:thumbsup:
Actually, I will go to TSC tomarrow and see if they have a universal type one.
   / King Kutter XB rotary cutter part? #5
your welcome. any time. :thumbsup:
Well I called today and priced the part ......$150!! You have to buy the whole sheild!! Guess I won't be buying that to replace the bell...just hope the shear pin don't place itself in my head!!!:mad:
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
1990 35 Ton Phelan Low Boy (A57453)
1990 35 Ton Phelan...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
