Loaded tires, 2nd valve, limited edition - M7040
   / Loaded tires, 2nd valve, limited edition - M7040
I wish it was local - so I could go see it...
   / Loaded tires, 2nd valve, limited edition - M7040 #12
   / Loaded tires, 2nd valve, limited edition - M7040 #13
"Limited Edition" is the marketing term for "screwup". :laughing:
   / Loaded tires, 2nd valve, limited edition - M7040 #14
Just an FYI:
The M5040, M6040 and M7040 are all the same size tractor (same chassis). The M6040 and M7040 have the same engine. (Of couse all three have different HP output).
There are a few other features that differ like limited slip front diff on the M7040 and cast iron wheels option on the M7040... but they are the same "size" tractor.
   / Loaded tires, 2nd valve, limited edition - M7040 #15
The M7040 cab tractor is available in a narrow version, but I can't say I've ever heard of a limited edition. But then again, different tractors are marketed in different regions...
   / Loaded tires, 2nd valve, limited edition - M7040 #16
You want to get as many remotes as possible. Things to use the remotes for.
2 for Top and Tilt hydraulics for the 3pt hitch.
4 more for a rear blade, so that you have angle, offset, tilt and gauge wheels. You could skip the tilt since you would already have the tilt capabilities from the Top and Tilt set.
1 for a down pressure unit for a post hole digger.
1 for hydraulic actuated rippers on that heavy duty box blade that you are going to get.
2 or 3 for a bat wing mower.
1 additional front remote for a grapple or 4n1 front loader bucket.
Self leveling loader would be nice also.
I'm sure that there are many more reasons to get remotes, but those are a few reasons to get as many as you can. Sadly:( I believe that 3 rear OEM remotes are all that is available, but it's a start.:thumbsup:
I'm sure that there are many more reasons to get remotes. When you first get your tractor your thinking that you won't ever need any, but over a little time you will change your thinking, believe me and anyone else that recommends getting as many as you can, GET AS MANY AS YOU CAN. ;)
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
