B7100 Rear Wheels Falling Off
   / B7100 Rear Wheels Falling Off #1
ojaikubota
Our B7100 has had both rear wheels fall off about 4 times over the past 2-3 years. The factory part that holds the wheel on the axle is a brass(?) pin with a small spring clip on the end. I reverted to this recently and it lasted about 2 months. Previously I have been going with long bolts and two nuts and they break. Has anyone else seen this? Is the problem that the hub on the wheel is worn? What to replace?
Thanks!
   / B7100 Rear Wheels Falling Off #2
Thanks!
Whoopsie:confused2:
Am I correct in assuming you have no wheel clamps, lug nuts or wheel bolts which hold the rim to the axle hub?
Our old boss buggies had four bolt hubs and they were a 2 by 4 kubota converted for underground mine use.
If you are using the wrong grade bolts and not torqueing them in the sequence needed with a torque wrench and not using blue Loctite...........
The center of the wheel should fit over the guide edge of the hub and then the wheel bolts are torqued to spec.
Unless I am missing something as the largest Kubota I worked on was a 40 horse in 1982 with 5 wheel bolts and it have wheel bolts which secured the dished wheel to the hub mount.
I am unsure if the were importing the entire tractor then or not but I believe they were.
Maybe Neil or Art can help with this quickly but your in initial description is something I have never dealt with the kubotas I worked with unless you have adjustable wheels to widen and narrow thew tread width and the dish and wheel are both damaged which sounds like what has happened and they must be replaced.
If your wheels have replaceable dishes you should replace them if possible or buy new complete wheels; something is wrong with your description as it sounds as if the wheel and replaceable dishes are both bad on both wheels and need to be replaced. please buy a torque wrench and blue loctitie and you will not longer have this issue.
   / B7100 Rear Wheels Falling Off #3
There is a new style hub for the B7100 axles. They work very well.:thumbsup::thumbsup:
I had the same problems. My wheels would tend to go to the inside rather than out and off. I tried shims but they worked out. Finally resorted to putting "Duct Tape" over the inside bolt so the broken pieces would stay in place and stop the tire from moving inward. Finally put the new hubs on and no problems there after.
   / B7100 Rear Wheels Falling Off #4
Like Egon said, get the new style wheel hubs. I replaced mine 2 or 3 years ago and all problems have stopped. It cost around $300.00 for both sides from Kubota to do the job. I recently say the same hubs on Ebay for around $100.00 each.
   / B7100 Rear Wheels Falling Off #5
Thats one sexy looking wheel hub there Egon; Was the adventure worth looking at the stub shafts and how was thier overall condition?
   / B7100 Rear Wheels Falling Off #6
Oh yes. The stubs were in good shape. The original hubs were a poor design.:)
The duct tape worked!:thumbsup: sort of.:)
   / B7100 Rear Wheels Falling Off #7
I am nominating this as the "under-statement of the year"! :laughing: I mean for goodness sakes you had to hold em together with duct tape!!:shocked:
   / B7100 Rear Wheels Falling Off #8
all right! if all else fails, use duct tape! :thumbsup:
   / B7100 Rear Wheels Falling Off #10
The excellence of duct tape in the above application is duly noted, and Red Green will be notified of the success of the current application.
The Duct Tape Council will also be notified of the projects success via National Public Radio and its home page and the chair duck (who is a Mallard this month) can remove it from his bill.
:thumbsup:
2012 Ford Escape XLT SUV (A44572)
2012 Ford Escape...
66in Dual Cylinder Grapple Bucket Skid Steer Attachment (A44571)
66in Dual Cylinder...
2020 Rawmaxx XCH-40-210K 40ft 20,000lb T/A Gooseneck Trailer (A45336)
2020 Rawmaxx...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE DAY CAB (A43003)
2007 FREIGHTLINER...
2016 Chevrolet Traverse 2LT SUV (A44572)
2016 Chevrolet...
John Deere 1435 Series II 60in Front Mower (A44572)
John Deere 1435...
