Kama TS 254c fluid pressures&relief valve locations
   / Kama TS 254c fluid pressures&relief valve locations
Update-found it was the pump not producing enough pressure. The numbers are unreadable, but after reading these forums, I'm guessing i need A "314" pump?
Were can i order it and/or is there another replacement that will bolt rite up? Any other suggestions regarding pump replacement welcome. I'm new to Chinese tractors and how the parts cross. thanks in advance.
   / Kama TS 254c fluid pressures&relief valve locations #12
No domestic manufactured pumps will fit, hence no crossover. Affordable, Circle-G, Keno, and Artrac will be your sources for a new pump, all supporting dealers.
:thumbsup:
Glad you found the problem.
   / Kama TS 254c fluid pressures&relief valve locations #13
Given that yours is configured as a PTO driven pump - as opposed to an engine driven pump - I'm thinkin' the most prudent choice would be to source it from the KAMA/TaiShan guy; Part Request from Artrac Company LLC
But I have to ask again: have you ever cleaned/replaced the filtration device? Locate the horizontal cylindrical housing on the left side of the hydraulic sump. Inside is a magnetic pickup that's wrapped in an 80 micron screen.
//greg//
//greg//
Yes. went through the system yesterday. Pump must have been dead headed in previous life(fluid began to foam and a seal is definatly blown on the pump. and, i believe it's a 306 thats on it.
I sent artrac an email but i have no part number to provide for them. no response as of yet.
   / Kama TS 254c fluid pressures&relief valve locations #15
My parts book shows numbers for the individual pump parts, but not one for an entire pump assembly. I'd be surprised if it's a 306 though. My TSC354C uses an engine driven 306 for steering, but I'm thinking it's likely got at least a 312 back at the PTO. Tractor's at a different location, but I'll try to remember to have a look asap.
The reason I'm speculating 312 or greater, is that mine's loader equipped - driven off the PTO. Lifting the front end off the ground is no problem at all. And I would suspect much slower lift and curl times with a 306.
//greg//
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
