B7100 Help... hydraulic screens
   / B7100 Help... hydraulic screens #1
Kenonf
Central Florida
Kubota L4200, B7100, B2920
I did a Hydraulic oil change, and for the first time i tried to clean the screens. I was able to remove the pump side but I was unable to remove the HST side. I tried some penetrating oil and tapped on it with a hammer, but no luck. I am very concerned about shearing off this bolt. Any suggestions. The screen on the pump side was clean, very clean for about 3000 hrs of use. Thank you
   / B7100 Help... hydraulic screens #2
Longer handle on the wrench may work but there is always the danger of breaking something. Impact wrench may be worth a try.:D
   / B7100 Help... hydraulic screens #3
I have pretty much gone to using an impact gun to get the screens out, much faster and easier.
Brian
PS. Make sure you are using a 26mm socket.
   / B7100 Help... hydraulic screens #4
Righty-tighty, lefty-loosey? :p
X2 on the impact. Although if you don't have one...I hesitate to even recommend this, because if you're not careful it can lead to a rounded-off bolt head, or worse... but...
A "poor man's" impact wrench is putting your wrench on the bolt, and while applying some leverage with one hand, tap/pound the end of the wrench with a hammer using your other hand. The combination of leverage (torque) and hammer (impact) works much better than either one by itself.
Just don't get too carried away and smash your wrench hand with the hammer. :D
   / B7100 Help... hydraulic screens #5
There are proper Hammer Wrenches out there.:D
images
   / B7100 Help... hydraulic screens #6
except maybe 6 point? But i never saw anything like it, I go with the red/blue hot wrench when in need.
   / B7100 Help... hydraulic screens #7
They will come in six point too. Maybe not so common anymore but there are places they are used.:D
   / B7100 Help... hydraulic screens #8
I read a note somewhere that 12 point socket/wrenches are what lead to rounded off bolt heads? That you are better off only using 6 point.
   / B7100 Help... hydraulic screens #9
Not having one doesn't really help in a pinch though, when you're laying under the tractor with your drain pan all ready and nowhere to go... now does it. :p
Rather strange that the one in your picture is 12-pt., unless it's for a 12-pt fastener head, or for somewhere where access is pretty limited. :confused:
I strongly dislike 12-pt sockets/wrenches... I don't use them unless there's no other option. There's a reason standard impact sockets are 6-pt.
Newer styles that grip on the flats instead of the corners are the way to go. :thumbsup:
OK Trivia Time: I've got one of these somewhere in my "special tools" chest. What is it for, and how do you use it? :D
   / B7100 Help... hydraulic screens #10
That is why the only 12-point sockets I have in my toolbox are for special applications all of the rest are 6-point. My engine building box has 12-points in it since a lot of ARP fasteners are 12-point.
Brian
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
