engine overload
   / engine overload #1
Joe Sau
Suva,Fiji
hitachi ex100-3
Bula Guys, having a problem with hitachi ex100-3. When i try to lift or move, it overloads the engine and sometimes stops the engine. Had the controls serviced but same problem occurs. Any ideas??
   / engine overload #2
Its hard to say in detail without a schematic symbolic drawing, but your excavator have a load sensing, LS, closed center system with a variable piston pump....seems like pump is receiving max load signal when you activate the control..... there should be a QC for a pressure gauge on the signal line....also check the pump supply pressure (pump out let line), which should be somewhere between 300-600psi when control are in neutral....and 600psi-5000 psi, depending on load, when control is activated...
You will need a 0-6000psi gauge...(some pressure reliefs are set over 5000psi)
Question: does it overload even if you just try to "feather" the control?
   / engine overload #3
Also, check ALL of the QC's to make sure they are fully engaged.
I have seen situations where a hose was left prressurized whan an implement was removed, serviced and the QC would not mate up properly without relieving the pressure in the hose.
It has happened to me once with the loader on my big tractor.
I had to take a large drift punch and a hammer and "pop" the nipple in the fitting. When doing this I strongly recommend gloves and safety glasses.
   / engine overload #4
Replace the fuel filters.
I have had similar situations on other machines.
Simply put the swash plate in the pump cannot flatten out quickly enough to stop the machine from stalling.
The machine is stalling as it does not have the horsepower, to lift the load due to blocked fuel filters.
If it doesnt stall you will find the hydrualics are very slow
Duff
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
Unused Delta Crash...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
