Haytech Grapple - need to adapt to my JD 40)X and JD 542
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I purchased a used Hay Tech grapple. It is setup for a JD 6xx loader. I want to have it work on either my John Deere 400x or 542 loaders.
I know I wil need to cut tall that stuff off and figure out a mount for my stuff.
I do not want to convert my stuff to skid steer - too many implements.
I have a set of Frontier forks that work on both loaders. I want the same setup on this grapple.
I wonder if somebody sells a weld on plate of some kind that i could just weld to the grapple frame and be in business.
Ideas?
Thanks,
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #2
Darin,
You can buy the hooks and pins from JD for little money if you want to make your own. Or you can even make your own with some CAT3 pins and some angle iron.
Darin,
That is cool - that would be the easiest. any idea about part numbers or where to look on jdparts.com?
Thanks,
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #4
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #6
Your the man - thanks, D.
Welcome. One more picture, it's of my Markham grapple. They weld the hooks and pins to a 3/8" plate.
Exactly what I need to do to this hay grapple.
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #8
Ideas?
Thanks,
D.
I have one idea ... sell it to me and you won't have to go thru that long drawn out process of chasing off to the JD Dealer, spending the cash on the parts ... not to mention all that darn time welding everything up!!!
NICE find ... I am looking for a grapple ... Quess you fiqured that out.
I have been looking for 5 years - I think I scored.
Does anybody have a manual and/or video on these things? I e-mailed them with no reply.
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #10
I am sure you got a good deal ... I am leaning towards the Rafter M grapple ... will build my own accumlator, for the FEL ...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
JOHN DEERE 661R LOT NUMBER 103 (A53084)
JOHN DEERE 661R...
2015 KUBOTA M9960 LOT NUMBER 210 (A53084)
2015 KUBOTA M9960...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
