Heavy Duty Rototiller advice
   / Heavy Duty Rototiller advice #1
jamest21165
I am a project superintendent for a heavy/highway contractor in Southeast Louisiana, and I am looking for some advice on tractors and rototillers.
We generally use a machine called a "stabilizer" to till powdered cement into soil, and a Rome disk to process wet clay/sandy soil to prepare the roadbed. It is not cost effective to use this stabilizer to just till soil, unless one is available and just sitting in the yard, not being used for soil cement work.
I am researching 100-125 hp tractors and a heavy duty rototiller to use in the soil preparation.
Any and all advice, comments, suggestions welcomed.
Thanks,
Jim
   / Heavy Duty Rototiller advice #2
Are you asking if you can use a stabilizer machine to roto till, similar to this. This machine will mix/till soil from 0 - 400 MM/0 - 15 in, or, are you thinking of a pull behind stabilizer machine.
Soil stabilizer SS400-23 machine products, buy Soil stabilizer SS400-23 machine products from alibaba.com
WBL22A Hydraulic Self-stabilized soil mixing machine products, buy WBL22A Hydraulic Self-stabilized soil mixing machine products from alibaba.com
I am wanting a 3 point hitch rototiller, so I can utilize the tractor in other areas when not tilling.
We use these for stabilization, but am not in the market for another one.
   / Heavy Duty Rototiller advice #6
Here is a picture of the First Choice RT22 series 10 ft roto tiller. $9,800 + shipping. Rated 90-160 HP tractors. Ken Sweet
   / Heavy Duty Rototiller advice #7
When you have the time look at
www.northwesttiller.com
High horse power rototiller with 14 inch actual cutting/tilling depth- meaning the 14 inch blade length of depth in tilling from the rotor.
It is a high horse power belt drive from the gear box to the tiller to absorb shock loads.
They occasionally have used rebuilt units for sale as well with warranties.
you can pack a lot of horse power in a very wide or narrow width tiller if desired.
Another option is a stone burier , where the european brands are a deeper cut.
The cane farmers in your neighborhood will love to hire you post harvest or in prep
you as you can prep can ground in one pass with one of these and add a bedding unit for
ridge tillage in the first pass to avoid wet root rot.
2023 Deere 331G (A50120)
2023 Deere 331G...
Toyota 42-6FGU25 Forklift (RUNS) (A50774)
Toyota 42-6FGU25...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
