Noise under my hood....
   / Noise under my hood.... #1
ozsevenzero
Massey GC 2610 TLB
I got a GC 2610 that has roughly 26 hours on it and it recently started making a whirring type noise whenever the tractor is getting some above average bucket or backhoe use. Happens especially in 4wd. Possibly low on hydro fluid. I haven't taken off the BH to check cuz i used it so much in the past few days but i am thinking that has something to do with it. Thoughts?
Also, has anyone ever used Rhino Liner, Line-X or Reflex liner on their hood. I am constantly pushing brush and what not with the bucket and have some dings and scratches.....was thinking about spraying the front quarter of the hood to protect it somewhat. I have a buddy getting his bed sprayed and the guy said he would knock it out for under $75 bucks.
   / Noise under my hood.... #2
The hydro pump is in the rear of the tractor. Does it do it when the tractor is stationary? Reason I ask is you say it happens in 4wd. How long is it running when it starts? Any leaks? Does the sound change when you change the RPM? I would check all the fluids to be on the safe side. It doesn't take very long to remove the BH. You could buy on of those mechanics mirrors on a long reach rod, and shine a flashlight to see the level of the hydro.
As for the Rino liner, should work, price is a little steep. You could go to a autoparts store and buy a small can and do it yourself for around $20.
   / Noise under my hood.... #3
Look up underneath the tractor, locate the shaft that goes from the engine to the transmission.
On the back of the shaft, there should be a 'fan'.
Sounds like something got into it.
Any blades missing?
If so, replace it.
EDIT: Also check under the hood, a stick or something could have gotten to a place it shouldn't be.
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2006 FORD F-250 (A52472)
2006 FORD F-250...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
New Long Forks (A53002)
New Long Forks...
Kubota RTV500 (A47384)
