GT 5000 Idiling Problems
   / GT 5000 Idiling Problems #1
jshine42
Sandpoint, Idaho
Craftsman GT 5000
Hello All. I'm new here but i have a problem with our GT 5000 Yard tractor. we have arpx 3 acres of lawn to mow here and our GT 5000 has run flawlessly the past 5 years; however, this year it developed a intersting problem. It starts up fine but when it's warmed up it acts like it wants to die and then it gets a shot of gas and revs back up. so it cycles like it wants to die then fires back up. And when I kill it it backfires. Anyone out there heard of this? and the answer is yes I did run Ethanol added fuel in this guy without a fuel Stabelizer. Any direction would be great. I use this tractor to maintain this property(not mine) and I just recently inheritied the tractor to use. Any direction would be great. I just changed the Oil/Oil Filter, Air Filter, and Spark plug. I was going to do the fuel filter and full fuel system flush. Any help would be great.
   / GT 5000 Idiling Problems #2
Change the fuel filter as you plan because after 5 years, it's over due. Also, get some "sea foam" from your local auto parts store or Walmart and add 3 Ozs to your fuel tank. Keep us posted for further suggestions.
Jim
   / GT 5000 Idiling Problems #3
you didnt mention what motor, if it is a kohler, shut down should be at 3/4 throttle to prevent a backfire, not at low idle like you would think. also after adding the seafoam, try running with the choke slightly on to help with the running problem and give the cleaner a chance to work.
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
2020 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A54607)
2020 VOLVO...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
