Fire Wood Storage Shed
   / Fire Wood Storage Shed #2
I am looking to build a fire wood storage shed. Does anyone have any ideas or plans maybee even some pictures of your fire wood shed ?
Not very helpful, but this is what i'm hoping to build later this year (before the snow starts to fly).
Should be able to put about 5 cords under roof. Little shed will be for saw stuff, tools and quad. Probably put the whole thing on a pad, and add a pistol range out behind it... :)
   / Fire Wood Storage Shed #3
Several years ago I built a classic pole shed with gable roof. Used sawmill lumber on everything except poles (6X6 treated). Shed is 14X28. Open on one side, 1X6 vertical on other three sides - with space between boards to let air circulate. Stacking 6' high, I can, in theory, store 19.68 cords. My outdoor wood fired boiler sticks out of one end so that the loading door is under cover. In reality, I probably stack closer to 12 cords at a time. It works great for our purposes.
Mike
   / Fire Wood Storage Shed #5
I stack most of mine along the back side of a metal carport out back, on pallets, covered with plastic tarps through the Fall & Winter. I usually have my wood cut by the first of the year to use the next Winter. Stack it (unsplit) at the farm until I have room at home. ~~ grnspot110
   / Fire Wood Storage Shed #8
How big are you looking for? I built a 8x12 that holds 3 cord of wood although I don't put that much in it. It's dark out so I couldn't get pictures of the back but the top 2 feet are also open to allow air flow.
   / Fire Wood Storage Shed #9
If the unit is just for wood storage, plenty of ventilation. Air movement is good thing. hearth.com is a great site
   / Fire Wood Storage Shed #10
I will have some pics of what I'm doing soon. I'm stacking my wood on pallets and then putting a few at a time inside my garage, when i need the wood. The wood will stay outside uncovered until needed. Sometime in early Nov i will move enough in for most of the winter.
2012 AGCO Rogator RG1100 (A48561)
2012 AGCO Rogator...
2020 GMC Sierra Crew Cab Pickup Truck (A44572)
2020 GMC Sierra...
2011 Isuzu NPR-HD Aries Sewer Viewer 16ft Box Truck (A46683)
2011 Isuzu NPR-HD...
2008 Ford F-250 Crew Cab Pickup Truck (A46684)
2008 Ford F-250...
Row Gator RG1100C (A48561)
Row Gator RG1100C...
2022 John Deere 8R 340 Row Crop Tractor (A48561)
2022 John Deere 8R...
