Need advice on thickness of metal to weld
   / Need advice on thickness of metal to weld #1
psient
Hi:
Can anyone tell me: what is the thickest metal I should be able to SMAW weld (arc weld) with a 180 amp welder?
Thanks,
Jon
   / Need advice on thickness of metal to weld #2
That depends on the type of joint/ size of weld.
You can weld 3 inch plate with 120 amps- as long as you have beveled edges at the joint and make multiple passes.
Sure, it'll take a while, but it can be welded, and welded properly.
How much can 180 amps weld in a single pass ?
I suppose you could weld 1/2 plate, using 5/32 (or maybe 3/16) rod, at 180 amps-using no bevels and just a single pass, but even then your resulting weld won't carry the same load as the base material.
Thanks towmotor
I want to make a sub-soiler and I was thinking of using 1" plate for the tine. I would have to attach the tine to a yoke. I had thought the yoke would be 3/8".
Jon
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
UNUSED CAPTOK CK-P45 MINI HYD BREAKER HAMMER (A57193)
UNUSED CAPTOK...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2015 Chevrolet Silverado (A53317)
2015 Chevrolet...
