2 Warning lights on after start L3650
   / 2 Warning lights on after start L3650 #1
Airdriver
Member
Flint Hill, VA.
I have a vintage 1991 L3650 which I recently started and 2 of the 3 warning lights (clogged air filter and not charging) not only came at start, but stayed on. This has not happened before. I cleaned the air filter, which needed attention but which was not clobbered and inspected the fan belt and wiring. Nothing was obviously wrong. The lights stayed on. I used it more than an hour and lights stayed on. Charger is on battery to see if needs an unusual amount of charging
I have had to leave it outside due to building material in the tractor shed so it got rained on a couple of times. Other than that, no changes.
Has anyone seen this sort of thing before?
Many thanks,
Hal
   / 2 Warning lights on after start L3650 #2
I had the same thing. :confused2: HELP to the top
   / 2 Warning lights on after start L3650 #3
Many thanks,
Hal
Don't know if this will help but on my 1989 L3750 if you did not have a Kubota brand battery in it which had a "third" lead built in, the charging light would come on. It charged and worked fine but the light stayed on the entire 6 or so years I owned it. Maybe your third lead corroded?
By the way, I was never able to figure out what the third lead did except to annoy the heck out of you unless you bought their batt.
Could be! It is a brand new phenomenon so something has changed. I'll look for the extra lead. Of course the clogged air filter light still remains. But it runs fine!
Thanks!
   / 2 Warning lights on after start L3650 #5
If the battery has a third lead that goes in to where it can contact the electrolyte, then it is to let you know when the fluid is low. I had the same thing on my motorcycle.
John Deere 6120E (A50323)
John Deere 6120E...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
