Pressure adjustment in Centrifugal Pump
   / Pressure adjustment in Centrifugal Pump #1
Arjun1
How to adjust the pressure in centrifugal pump ? detailed process pls.
thanx.
   / Pressure adjustment in Centrifugal Pump #3
Centrifugal pumps are pretty limited to "pressure adjustment".
Diameter and RPM is pretty well determining factors in a reachable "head pressure". The impellar basically throws the liquid.
Now if this pump worked fine and started losing developed head, and assuming impellar is fine, wear ring is worn enough that internal leakage may be the biggest problem. I have worked around Sulzer pumps, and some of them have an adjustable wear ring. Packing can also cause some problem to pressure, but most of time it will create cavitation.
   / Pressure adjustment in Centrifugal Pump #4
Some times the impeller is shaved down for less capacity. This is a non reversible operation.
With some types of stacked impeller pumps impellers may be removed. With this type of pump a hole may be drilled through the diffuser?? to reduce capacity.
With impeller pumps flow is usually controlled by a discharge side valve or bypass valve or both.
   / Pressure adjustment in Centrifugal Pump #5
Egon, you are correct. I have that Tim The Tool Man Taylor thought of more power!!!! Maybe he wanted less flow, or pressure.
TANK MANIFOLD (A55745)
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2016 Bobcat E85 Midi Excavator (A55851)
2016 Bobcat E85...
2002 Chevrolet S10 Pickup Truck (A55852)
2002 Chevrolet S10...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A55314)
Magnolia Trailer...
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
