Extra Valve for Hyd Thumb ?
   / Extra Valve for Hyd Thumb ? #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
I have access to full fabrication shop. After looking at many thumbs I can buy online it seems to me the simplest one is the one that uses the bucket pin and has hydraulic cylinder and one weld on cylinder tab. Since this is going on my backhoe where can I tap off the hydraulics for an extra lever to work the thumb? I have a Kelly B30F Hoe attachment and it had it's own pump setup that runs off the pto. I figured between some half inch plate, longer pin, hyd cylinder from Northern tool it's gotta be cheaper then the 1000-1500 some of these companies want.
   / Extra Valve for Hyd Thumb ? #2
I have a 480D Case Backhoe and I priced new thumbs as well. Cheapest I could find was like $1,300:(
I decided to make my own, which I did, and the total cost for metal was less then $200.00.
I only needed the adjustable type without the cylinder but I am sure the hydraulic feature would be very useful.:thumbsup:
With using these diverter valves is that any preference on what to tap off of? or split with. Stabilzers or BH arm?
   / Extra Valve for Hyd Thumb ? #5
Search around in the hydraulics forum;)
   / Extra Valve for Hyd Thumb ? #6
once you go to a thumb, hyd is next so save time just go hyd right away.now for the valve a pb valve to a new one is the easyest,if your valves do'nt have a pb you can put the new one in front of the old set. on my valve its a foot valve right from the manufactor so it was designed for the bh but it was a @@! to install
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
CONTACT INFO (A53084)
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
22002 (A51694)
22002 (A51694)
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
