installing new ignition switch
   / installing new ignition switch #1
moe52
gilson/older 14hp garden tractor
how do i rewire a new ign. sw.trying to bypass an ecam switch
   / installing new ignition switch #2
It will be difficult to advise, as there are many different kinds of ign switches. Some have 2 to 6 terminals, and they are connected for a specific task. For instance , on my Kohler, there is a wire to ground the magneto, and some just disconnects the 12 v .
Can you post a picture of the back of the switch, and indicate any lettering?
   / installing new ignition switch #3
I don't understand your question. I just put a new switch on my '80's vintage Snapper tractor - the 6-terminal switch simply unplugged from it's automotive-type connector, and I plugged in a new one. The new switch w/ key cost about $15.
JayC
   / installing new ignition switch #4
Whatever an ecam switch is, he is wanting to bypass it, and wire in a new switch. He could get a simple ign switch or one that has 5 or 6 terminals. and maybe a terminal that would ground the magneto if the motor has one.
   / installing new ignition switch #5
I have no idea what a ecam switch is either. Hey J.J. The weather here about 20 miles from your old home town of Clinton is about 90 degrees. are you enjoying your cooler weather there? lol Pete :)
   / installing new ignition switch #6
It's still hot here, running about 88 to 92. Looking forward to some cooler weather. This summers heat has whipped up on me. Up to 4 years ago, I was landscaping about 8 hrs a bay, toting backpack bowers, etc. I don't know how I did it, but I just kept on working, until my feet starting hurting.
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
UNUSED DIGGIT 72" HYD MULCHING HEAD (A54757)
UNUSED DIGGIT 72"...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
