Urgent Well Pump Question
   / Urgent Well Pump Question #1
Stringer
Member
Hey guys i have a 1.3 acre vacant lot im trying to build a home on. It came with a 2" above ground system that is junk and I'm having it abandoned. The well guy is coming tomorrow to put a new well in, a 4" submursible system with a 1HP motor. He plans to drill about 100 ft deep. This was just sprung on me moments ago. He is out of town and cannot be reached right now (figures)
Questions: Is a 1hp motor going to be enough for say, a 3 bathroom home and irrigation for many trees? The distance from well to proposed home is probably 200 feet or more. Any brands better than others? Basicly should I ask for a certain pump or just take whatever 1hp one he brings? I just don't know, and it's so permanent so I thought i'd get some opinions! Thanks! :eek:
   / Urgent Well Pump Question #2
I'd ask the well driller for a recommendation for size after he determines how much water the well puts out. Mine was 23 gallons per minute and I went with a larger (I think 3/4 hp) motor on his recommendation.
Other considerations: I've never ended up using the full capacity and it requires a bigger generator to start it in a power outage.
   / Urgent Well Pump Question #3
1 HP is the standard here in N Central FL. Should provide great volume & pressure.
I have almost the exact same scenario (3BR house on 1 acre) & my 1 HP pump provide great volume & pressure, including a kick-butt irrigation system that does the whole acre (4 zones with 7 heads on each).
   / Urgent Well Pump Question #4
A 1 HP motor will drive a 25 gallon per minute pump. The questions that you do not have answered at this time are: Well tank what size? How far is the water down in the well from the top, 20, 30, 40 feet? This will have a bearing on how many gallons per minutes the pump will actually produce. What size water supply line do you intend to use? A 1/2" supply line will greatly restrict water volume, whereas a 2" water supply line will provide plenty of volume. Water pressure will be the same in both, 1/2" and 2" but the water volume, gallons per minutes from the facuet will be greatly reduced if 1/2" line is used. What PSI do you have in mind for the system, 40, 50, 60? The tank and the pump have got to be sized together to prevent damage to the pump. Some of the new constant flow pumps allow for a small tank and maintain good pressure by running on demand. The list goes on and on. I would recommend doing a web search on well pumps and well tanks.
   / Urgent Well Pump Question #5
No one can answer that till the well is drilled. You need to know what is the well recovery rate, and only the driller can answer that.
A 8HP motor will is a waste of money if the well only produces 2 gallons a minute.
On the other hand if the well produces 100 gallons a minute then it's not that much more to go with a larger motor while the well is open.
From what well guys have told me it's better for a pump to run a longer time than a shorter time - don't know why just what I've been told, so smaller motor is better than larger motor.
   / Urgent Well Pump Question #6
The undersize vs oversize issue has to do with pump short cycling. If you are going to use lots of water all the time bigger is better. If you aren't going to use it, it will cause it to run too short a time and that isn't good. There are systems, like Jaccuzi had, that will keep it running as long as there is demand, but it can cause pressure issues if it is too much over sized. Then you need regulators and controls. Some of the high end pumps have a sensor system that ramps the pump up as need. I have no experience with those.
wow this is all great advice, thanks alot!
sounds like a 1hp is probably ideal, but i'll leave it to the installer and see what he finds tomorrow. interesting info about short cycling. Apparently it's the same as air conditioning units. Bigger is not better due to short cycling, or so i've read.
   / Urgent Well Pump Question #8
Don't worry about it now. You can deal with these issues tomorrow.
You can always increase your storage capacity as compensation anyhow.
   / Urgent Well Pump Question #9
These guys build some of the best well pumps! When dealing with water systems a little over kill is sooooo much better than a little under kill.:thumbsup:
GRUNDFOS
   / Urgent Well Pump Question #10
The question is head for GPM, not just HP.
Most city water systems with a 3/4" line coming in a house nets aprox 5 gpm through water meter base.
I would think if your well contractor has been in business long enough, feel comfort in to know he would probably have good knowledge in what he is doing.
If you have large amounts of water needed for short times, or other types of usage, bring concern up with him, for I am sure with economy as is, he would not want a unhappy customer.
   / Urgent Well Pump Question #11
The HP demanded by the pump will depend on more then just your GPM. The depth of the well and the height of the water in the well (head pressure) will determine not only the size HP but the number of stages the pump will need to get the water to the top and then pressurized to the pressure you want, typically about 45 to 50 PSI. For every 2.3 feet of height you need one pound of pressure just to lift the water or put another way, a column of water 2.3 feet high will exert 1 PSI pressure at the bottom of the column.
The pressure tank has almost nothing to do with storage but simply a means of keeping pressure on the plumbing system via a compressed volume of air. The larger or more pressure tanks you have, the longer you can flow water before the pump kicks back on to get back to your desired pressure. Cut in and cut out pressures typically vary by about 10 PSI. To get extra fancy and have a constant pressure you can get a special pump set up on a frequency drive that will spin the pump at the speed necessary to match your flow rate that will maintain a constant pressure. I use large frequency drives on 3 phase pump motors exclusively. I do not know how well they work on home type models but have heard some bad comments about them in the past. Check Franklin for some ideas.
   / Urgent Well Pump Question #12
Most home consumption is either on or off. You can't run a VFD much lower than 20hz anyway - little to no advantage in a home type application. You also run the risk of overheating the motor as such low speeds.
   / Urgent Well Pump Question #13
That all depends on where you live. If your in the West, you irrigate all the time. They are far more popular here I suspect than back East where your demand is pretty much for domestic purposes with relatively low flow rates. Here, not unusual to have at least 10 GPM to 100's GPM if you can get it. The pumps I maintain supply our small community with irrigation and fire hydrant water with a capacity of about 1300 GPM @ 50 PSI. They are staged to kick in as demand increases and sleep as the demand falls off.
Heres a link with a little more info... http://www.envisupply.com/equipment/constant_pressure_pump.html
   / Urgent Well Pump Question #14
I may be a little late here but the pump HP tells you very little. Pumps are rated in both GMP and HP. You're well driller should be able to size the pump up for you. To figure out the correct size of pump needed you'll need to know the depth the pump will be placed in the well, the make up of the well, and the total height the water will need to be pushed (the low point being where the pump is located in the well to the highest fixture in the house).
The depth of the well will be determined by the the size of the house (potential water demand), any other water useages, and water make up rates as he's drilling. After he drills the hole and has the correct water make up rate he then can size the pump. Around here the drillers have a supply of pumps and will choose as needed. As a rule of thumb the higher HP the more it will cost and the lower the GMP of the pump the more it will cost (more stages). Secondly the larger the HP the larger the wire size needed for the pump.
To answer your question a 1hp may be needed or it could just be extra cost for nothing gained.
   / Urgent Well Pump Question #15
A cheaper and simplier means to regulate a constant pressure for residentual use is to simply install an adjustable pressure regulating valve on the output from the system to the house. They are typically set just a few PSI below the cut on pressure of the well system.
   / Urgent Well Pump Question #16
I have used them. They are pretty slick. Hard for folks to understand how they work, but they do work and they are relatively cheap. Flow control valves basically pinch off the output side of the pump as the pressure gets closer to the cutout. When you do that, you knock the current down on the pump. I have watched the current or amp meter drop as the flow control slowly chokes off the output. That would be a nice option for folks to consider. I did a quick Google of flow control trying to remember the company I used in the past. They were out of Texas.
Just remembered, http://www.cyclestopvalves.com/techq_8.html
   / Urgent Well Pump Question #17
Just remembered, Cycle Stop Valves, Inc.
I used something like this:
223, 223S High Capacity Water Pressure Reducing Valves, Water Pressure Reducing Valves - Super Capacity, Water Safety & Flow Control - Watts
It might have actually been this one. Not sure without looking it up. Used 1" size to meet my piping requirements.
Actually, I don't think it was this one as I was looking for one which went to a lower pressure and IIRC the one I got went down to 15 PSI.
   / Urgent Well Pump Question #18
I love my Franklin VFD constant pressure system. I'll never go back to the old system of using a large bladder tank again. Well is 95 feet deep, yields 68 gpm and pump yields 32 gpm wide open off the pump discharge. I can finally run kitchen tap, bathroom tap, shower and laundry at the same time while running 2 sprinklers on the yard/garden.
The VFD seems to be easier on my generator as it spins up slowly and doesn't hammer then genset so much. Of course, clean power from the genset is essential with this system.
I agree with the others....wait til the driller is finished and see what he recommends. My well is in a huge gravel lense (glacial moraine where I live). I was expecting 200 ft or more to get through the limestone bedrock like some of my neighbors have.....but I got lucky.
   / Urgent Well Pump Question #19
I was wondering about that Brian, the ability to get a well pump going on a VFD, it has to be much easier to do especially if your generator is marginal. The VFD's I manage are very nice, two are Franklin. After using Cyclestop valves, I really like the simplicity of the 3 phase frequency drives I keep up. They are actually cheaper than the 6", 4" and 2" Cyclestop valves I would need. I'm would be inclined to do the same as you if I was on a well.
   / Urgent Well Pump Question #20
Hello everybody! I'm new here.
Why abandon the well? If the old well is not in your way or otherwise poses no health or safety concerns, keep it and repair it later.
Use your new well for the house and use the old well to water your trees and garden. No sense using potable water on a tree. Tree don't care. And if your main well for the house ever stop working you'll at least have water for laundry and bath.
Just my opinion.
Have a great day!
iDrive TDS-2010H...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
Towable Centrifugal Water Pump (A59228)
Towable...
2007 CATERPILLAR D6N HIGH TRACK CRAWLER DOZER (A60429)
2007 CATERPILLAR...
