Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
question is what color is the smoke.. blue or black?
blue is oil.. black is rich carb.
next. what constitutes a rebuild. can be anything from full rebuild.. new crank, cam, cam inserts.. new valvs, seats, etc.. or alot less. to some a rbuild is a new set of main and rod bearings, new rings, ream the ridge, maybee hand lap the valves and go.
unless you did the full enchalada.. you might have leaky intake seals.. or loose tolerance inthe cyl bores.
what's yer compression like.. dry vs wet?
yes.. a heavier oil can limit consumption.. but also makes for slower to rise oil pressure in cold weather, plus 'less' energy savings. still.. IMHO.. 10w30 is too light an oil for even a rebuilt tight N. i'd go 15w40 minimum..
soundguy
soundguy
I know an old farmer who used older tractors on his farm, such as 8 and 9Ns, Jubilees and some older JDs. I have two tractors I use, a 8N and JD5103. Dad and I rebuilt the engine in the 8N about 9 years ago and have probably put around 500-600 hrs on it. It still runs strong, but I notice it smokes some, especially under a load. The above mentioned fellow said when his 8N and 9N started to smoke some, he went with a heavier weight oil, maybe a 40wt. I run 10w-30 in my 8N and wondered if he was on to something. Anyone ever try this to see if they can get by longer before a rebuild? It seems to me the heavier weight oil will rob the engine of some power, not help it. Thoughts?
