Had a buddy of mine look under the brush hog as I engauged the pto (I know it sounds dumb) but the blades are banging toether. I contacted 2 different dealers and spoke with their shop formans and both told me Mahindra has a problem with this and I would just have to live with it. I then spoke with the district rep, and he said Mahindra has an issue with this and it was even worse without the accumulator which is what the fix is supposed to be. The rep said Mahindra wasn't going to put the accumulators on the tractors but he convinced them otherwise. The rep said not to even try to run a rotary mower without a slip clutch, or you will spend all of your time replacing shear bolts, in short I was told to live with it. I quote, "It's just the nature of the beast" I say I spent over $20,000.00 on a new tractor and it needs to be right. Any suggestions on my next course of action. I have tried to ease it in with the clutch with no luck, (I was told there is no easing into the pto its all or none by the rep.) I even pulled into some 6' tall johnson grass and all it did was sling the blades together and lock them and I had to take a sledge and knock them apart. I have also made sure the blades were straight across from each other before engauging the pto..no luck. My old 2810 didn't do this.
