Two stage hydraulic pumps-are log splitters their only application?
   / Two stage hydraulic pumps-are log splitters their only application? #1
IHDiesel73L
I've been slowly accumulating the parts needed to build a decent sized splitter, most are used and I've gotten them for free or at very low cost. The one missing piece so far is the pump. From what I've seen my choices are either buy new or hope to find a splitter with a dead engine (which kind of defeats the purpose of what I'm doing)-everywhere else I look for used/surplus items has only single stage pumps. Any ideas?
These people have all the 2 stage pumps you will need. Choose a pump based on the engine you will use.
https://www.surpluscenter.com/sort.asp?catname=hydraulic&keyword=HP2S
Call me cheap, but those pumps are all new units. The cheapest 16 GPM pump is $135 which is more than I want to spend. I suppose if I have to I will, but I was hoping that I could get some ideas here about the kinds of equipment that normally use 2 stage pumps (if there are any) so that I comb my local salvage yard for one.
   / Two stage hydraulic pumps-are log splitters their only application? #4
You can use a single stage pump, but the HP required to power it will be a lot more. A 11 GPM single stage pump using 3000 psi, will require about a 23 HP engine.
A 16 GPM single stage pump would require about 33 HP.
A power steering pump will provide about 1500 psi pressure.
   / Two stage hydraulic pumps-are log splitters their only application? #5
What about a single acting cylinder and a big return spring. Or a small automatic transmission between the motor and the pump, lol.
Sounds like missing limbs and busted pumps...nevermind. :)
Since all I have to work with is a salvaged 12 HP Briggs and Stratton a single stage is out of the question. Perhaps my best bet is going with the new 2 stage pump for $135.
   / Two stage hydraulic pumps-are log splitters their only application? #7
You have enough HP using the 12 HP engine, to run a 22 GPM 2 stage pump, but it is expensive, at $399.
   / Two stage hydraulic pumps-are log splitters their only application? #8
Yes they can be used elsewhere but the most common application by far is on logsplitters.
I have seen them used on larger laoding docks as an example.
Roy
Ha! That would probably cycle nice and quick! I think I'll stick to the 16 GPM pump. That's what all of the 30 ton splitters from Northern Tool use, so it ought to be good enough for me. I have an 8 ton right now that's a little small but it does ok. 22 more tons should be more than enough for what I need :D Plus its always good to be a little overpowered because the engine is really working as hard right?
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2019 Chevrolet Express 2500 Cargo Van (A51692)
2019 Chevrolet...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
