48 inch mower deck spindle bearing
   / 48 inch mower deck spindle bearing #1
caseyvand
Dunvegan, Ontario, Canada
Hi.....The john Deere part number is JD M110024 for the 48 inch mower deck spindle bearing. Can anyone confirm that this is the same as a 6204 bearing.
Thanks......Casey
   / 48 inch mower deck spindle bearing #2
Hello Casey,
From what I read on another forum,they are the same bearing. Is there a reason for not wanting to use the JD bearing?
Greg
Hello Casey,
Greg
Hi Greg.......Thanks for the info. I do not have any problems with John Deere parts. I already have some 6204 bearings on hand for spares for another mower deck and was wondering if I needed a different size.
Thanks.......Casey
   / 48 inch mower deck spindle bearing #4
Just FYI, my LT150 uses 6203 bearings on the deck. They are about $6 at JD, about the same as at an auto parts store. I found them for $1.95 at Texas Bearing. Another bearing dealer (can't remember the name) offered them to me for $1.75. I go through lots of them on my JD. Also, my deck has idler pulleys that use the same bearing. JD only services them as pulley assemblies costing about $12. So I drilled out the spot welds that hold the pulley halves together and put small bolts and nuts back in. Now I just unbolt the two halves and put a $2 bearing in that $12 pulley. The savings really add up fast!
   / 48 inch mower deck spindle bearing #5
I know this is an old post, but "search" found it, and I need some bearings for my 48 inch Case 446 Hydriv Deck. Is this the bearing numbers I need to oredr one?
   / 48 inch mower deck spindle bearing #6
I would think it would be coincidence if another make of deck used the same bearing but it could be. However, if you take out the old bearing it will have a part # on it that makes sense to a bearing dealer. Hope this helps.
Sany SY35U Pro Mini Excavator (A52384)
Sany SY35U Pro...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
SCHAFFER 2430SLT LOT NUMBER 114 (A53084)
SCHAFFER 2430SLT...
2003 INTERNATIONAL 7600 6X4 DUMP TRUCK (A51247)
2003 INTERNATIONAL...
