pressure washer to draw from a tank??
   / pressure washer to draw from a tank?? #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I know this is an old question but I can't find good answers. i need a washer that will be supplied from a 200 gal. tank. Most washers mention a minimum innput pressure or flow, but most info is vague. I have only found one that specificaly states it will draw from a tank but it is pricey. Anyone use or know of a specific washer that will work? I will only use it occasionally to wash off a tractor, so I want one with minimal power and minimal cost.
   / pressure washer to draw from a tank?? #2
I have a pressure washer I got from harbor freight...it will ONLY work from a pressurized water hose....and even the hose MUST not have kinks and be turned on full blast.
I tried to run it from a non pressurized water tank that was raised 10 feet in the air... would not work....no water flow our of pressure washer, and it would cycle on and off funny. I was concerned about burning the pump/motor up.
Net...I DON'T think you could find a pressure washer that would work from a non pressurized water source.
   / pressure washer to draw from a tank?? #3
I have a Karcher that will work from a tank. Don't have it here, so no model number... Sorry!
   / pressure washer to draw from a tank?? #4
We use truck mounted tank/pressure washers at work a lot. Even the high dollar units don't like a no/low pressure feed.
Our cure was to install little 12v buster pumps under the tanks to supply the pressure washer.
We also added a simple screen type strainer with a clear bowl just in front of the booster pump to keep out the algae.
Hope that helps.
E/S
Hope that helps.
E/S
Yes, I have tried that also, and even used my little Honda gas pump inline to feed the washer. It just complicates things however. I do know that some pressure washers will draw. Last year I saw some online that specifically stated they were capable of that, but I just can't remember where! Surely someone pressure washes out of a tank. How do these mobile car detail people rig their tanks? Do they all use a pump first?
   / pressure washer to draw from a tank?? #6
i know my karcher brand gas powered pressure washer works fine with the washer on the ground and the tank in the bed of the truck, thats how i wash all my maple sap tanks that stay in the woods at the end of the maple syrup season.
   / pressure washer to draw from a tank?? #8
I use a Comet AXD 2520 pump with a 4hp Honda GC engine with no problems ( 2.5 gpm @2000psi). No problems with it drawing the water from the tank. It originally came on a 2 wheel hand cart, but is wasn't practical for my useage. Put it on a small wagon with a 30 gallon tank to make it portable.
   / pressure washer to draw from a tank?? #9
I had the need to do the same around 10 years ago at a remote site without electricity. Here's what I did.
I attached the pressure washer (borrowed) to a sump pump (borrowed). The sump pump was in the barrel (free - dumpster dive) with a ladies nylons as a filter. The sump pump was powered by a generator (borrowed) and the the 55 gallon barrel was filled manually with 5 gallon buckets from the lake.
So I figure my outlay was $2 for the panty hose and countless trips with 2x 5 gallon buckets (always easier than 1). Not sure I would want to do this often... Have fun.
   / pressure washer to draw from a tank?? #10
I have two power washers that will draw from a barrel. They do not have soap injectors so I draw soapy water out of a garbage can and then connect the garden hose for rising. Here is a picture of one of them showing the label. It is pretty old so the company may not even be around anymore.
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
TORO Z MASTER 2000 ZERO TURN MOWER (A51247)
TORO Z MASTER 2000...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
