Black stuff in coolant
   / Black stuff in coolant #1
rharkins
Member
Edmonson, MO
New Holland 3040
My T3040 Boomer is a year old this month, and I suspect it sat around the lot for nearly a year. I drained the coolant, flushed, and refilled it. As I was bottling the old coolant for disposal, I found what looked like a bit of black sand in the drain pan. Unfortunately, I didn't stick my finger in it to see what the texture was.
Seems to me it could be either sand from the block casting process, or maybe rubber crumbles from the inside of the hoses. I'm thinking it was a tiny bit of sand that didn't get blown out of the cooling passages before machining.
I plan on asking my service manager the next time I stop by.
Any ideas here?
Thanks!
   / Black stuff in coolant #2
I think you are absolutely correct in your assumption. That's why NH recommends an annual coolant change with 50/50 permanent anti-freeze.
   / Black stuff in coolant #3
Any ideas here?
Thanks!
After the casting, the inside is cleaned and they paint it in some enamel paint. I can't imagine any sand will be left over or at least at it will be encapsulated by paint. I think inside of rubber hose might have peeled off during the installation especially if it were a tight fit.
jc,
2017 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2017 GENIE GS-1930...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
JOHN DEERE 850K...
