Craig B
Member
- Joined
- Aug 31, 2010
- Messages
- 46
- Tractor
- JD 850, JD 430
I love this forum. I have gained a great deal of knowledge reading many threads. Thanks! I have had some minor problems with my 1981 JD 850 that were resolved with help in part from the forum.
Currently I am in the market for a replacement for the 850. My needs have changed slightly so I think a 3520 or 3720 would be the appropriate choice. What do you think? The uses I have are prioritized as follows:
1. Mowing- I live on 7 acres and keep 4 1/2 or so finish mowed. I currently use two tractors the 850 with a mmm and JD 430 with mulch kit for the finish work. I will need to cut another 25 acres 3-4 times per year. It was cut last year and is just tall weeds and grass. Think of it as very poor quality hay with no heavy brush or saplings.
2. Loader Work- I will move heavy items around, spread dirt/gravel. Also clean up a few down trees.
3. Box Blade-Maintain 400 gravel drive and infrequently some light finish grading of the yard.
4. Back Hoe-I DO NOT need one but I will not rule out owning one in the future. Everything I need to do I can accomplish with a FEL. But hey, who doesn稚 want one?
Questions:
1. I like the horsepower of the 3520 and the 3720 but would a 3320 do instead? What do you think? I plan on running a 6 bush hog and a mmm or a rear finish mower. Should I save my money on horsepower and spend it on implements? If I were only taking care of where I live a 2x20 series would suffice.
2. Would the above mentioned tractors operate the 6 cutter with authority? Or should I stick with a 5 since I wont be using the rotary cutter that often. My thoughts are if a 6 starts to bog I can make a partial pass. But, I will have the full 6 feet available for the thinner/shorter areas.
3. What size box blade is recommended for # 3 above? I have 0 experience with one so no idea. I have used a rear blade and a drag my father made from an old RR tie. It worked great except for the windrows that developed off the ends when the gravel piled up in front.
4. Does anyone have any experience with a mmm on these tractors? I am thinking about lawn damage and quality of cut. I have quite a few trees and the RFM would be a concern navigating those. My 850 causes zero damage to the lawn and leaves a superior finish. It has ag tires on the back and turf on the front. Plus, it痴 mmm makes it easy to get close to the trees.
5. This will not influence my purchase decision but I am curious what kind of fuel economy can be expected with these tractors. How much fuel can I expect to burn per hour while operating the bush hog?
I am not in a hurry to make this purchase. I want to carefully think this through so I will buy once and keep for many many years. The 850 is a 1981 and the 430 is a 1987. My father bought both new. I would not rule out a nice used one but I like the idea of warranty and the peace of mind. What is the dollar value of that? Thanks in advance for your input and thoughts!
Craig
Questions:
Craig
