Air Pressure in Loaded tires.
   / Air Pressure in Loaded tires. #1
ruralruss
NW Georgia
Kubota B3200
I just had my rears on my B3200 loaded and I was wondering what is the proper air pressure to use. It seems I read somewhere that you need to drop it below non loaded recommended because of the reduced air volume. What is your experience?
Russ
   / Air Pressure in Loaded tires. #2
I had mine loaded w/ rimguard and the guy said leave them be. If you go to check the pressure the rimguard will effect your valve stem and it'll leak because it won't seat properly.
   / Air Pressure in Loaded tires. #3
Why would you need to change the pressure? I know the air volume is reduced because of the added fluid, but I would think that the sugessted psi would remain the same.
   / Air Pressure in Loaded tires. #4
Yep, the volume of air is reduced, but I would keep the same pressure. Regular tire gauges work, but getting any liquid in them may cause premature corrosion, so they make gauges specifically for air/liquid and they cost little, if any, more than any other gauge.
My personal preferred method to check the tire air pressure with loaded tires is to (1) stop with the valve stem at the top; 12 o'clock position, (2) give it one short blast of air from the compressor to clear the valve stem of any moisture, and (3) then use the tire gauge.
Eventually you will have to add more air! Why would it effect the valve stem unless it is gritty or something.
Russ
The tires have to have some give to them. If you hit a rock with only air in the tires they give x amount. The fluid will not compress like air will so if the tires are fill with fluid up to 75% volume and you hit that rock the greatly decreased volume of air compresses much faster causing the tire to not give as much. This can cause shock loading on the rear axles.
Russ
   / Air Pressure in Loaded tires. #7
No clue Russ. Just relaying what the tire guy told me that fills tires for a living. IMHO :confused2:It may or may not leak but this is what he said...
   / Air Pressure in Loaded tires. #8
Reminds me of when I was a teenager working in my dad's service station in the days when we pumped the gas, washed all the windows, checked the oil, etc. without being asked to. So many folks had low tires that I also got into the habit of checking tire pressure until one day, I started checking the tire pressure on a customer's car and he became quite irate; told me the tires were OK, but messing with valve stems would cause them to start leaking.
   / Air Pressure in Loaded tires. #9
Well menthinal and water mix don't make valve stem leak,,sounds like if you don't add a little air when you should you'll be spinning on your rims before long.
   / Air Pressure in Loaded tires. #10
I was wondering that myself ... I have a gauge for fluid filled tires (was the same price as the other pen type one at tsc) ... I just pinged the dealer to see what he suggests ... I would imagine they ought to be the same as unloaded but stranger things have been know to happen
2001 JUSTIN 14 MOTORCYCLE TRAILER (A53843)
2001 JUSTIN 14...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
