TheWizardofTN
- Joined
- Sep 19, 2010
- Messages
- 4
- Tractor
- Ford 4 Cyllinder
Hi,
I have an older Ford 4 cyllinder tractor which starts by turning the ignition 1/4 turn, then putting the gear shift in the start position.
I was running it this morning, turned it off, then back on, and it made a whine but then nothing when I engaged the gear shift.
I started checking electrical connections in case something had shifted, and found that the connection between ignition coil and distributor was just a loose wire. I've replaced that and it still doesn't start.
Should I be thinking 'starter,' or something else?
Thanks!
Thanks!
