kubota BH90 hydraulic leak
   / kubota BH90 hydraulic leak
THIS IS WHAT IS LEAKING, 2 OF THEM, YOU CAN SEE THE DRIPS
   / kubota BH90 hydraulic leak #13
anyone know if this is an easy fix
I dont know about this specific valve.....needexplosion part list or cross section drawing....
but except from getting linkage and end caps off, it's not that hard ....just be careful use common sense
It believe it is these low pressure O-rings that are leaking....CHECK OUT WHAT CAUSES RAISED PRESSURE IN RETURN LINE!!!!
example how it can be layed out...I used this picture for another thread....THIS IS NOT YOUR VALVE!!
   / kubota BH90 hydraulic leak #14
I can not exactly see where it is leaking.
Is this still on warranty with 25 hours?
Just guessing where it is leaking, probably not to difficult to fix.
   / kubota BH90 hydraulic leak #15
It wasnt hit, there is no damage, I did notice that after driving around or parking the backhoe arm will lower by itself.
Can't help on the leaks but the lowering of the BH and the stabilizers is common, even with no leaks. I have a hooked rope tying the stabilizers together and put the pin in the BH when not in use.
ok its been a while and still have not fixed the problem
   / kubota BH90 hydraulic leak #17
easy fix...just disconnect linkage from spool and unscrew the two allen screws, slide the seal assy off...
wet the seals with hydr fluid before re assemble,, slide back onto spool carefully...
:thumbsup:
with b/h disconnected sitting on blocks, will there be hydraulic pressure when I remove the Allen screws? thanks for your help
   / kubota BH90 hydraulic leak #19
If you move all the levers through their range, that should relieve any pressure caused by temp variation.
2001 CIRM Bumper Pull Utility Trailer (A53117)
2001 CIRM Bumper...
6 BENCH GRINDER (A53843)
6 BENCH GRINDER...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2004 Ford F-250 Service Truck (A53422)
2004 Ford F-250...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
