Where do cultipacker wheels come from?
   / Where do cultipacker wheels come from? #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
Aside from Brillion, Dunham, Deere and some of the older brand cultipackers, does anyone know what country is making the wheels for these new cultipackers? I am beginning to get feedback that the new wheels are breaking prematurely. Ken Sweet
   / Where do cultipacker wheels come from? #2
If someone says China, I would believe it. :)
I gather from your post, that the brands mentioned are not breaking prematurely (does premature mean while in the lot or before field use? ).
The way some use them (behind ATV's, and going fast), I'm not surprised to hear of breakage however.
The older packers have been working hard for 20-30-40-50 years with little or no wheel breaking and I am hearing that packers made by companies that just added New cultipackers (in the last 3-5 years) to the products they manufacture are having castings break in the field after limited usage. Ken Sweet
   / Where do cultipacker wheels come from? #4
It wouldn't have anything to do with what country they're being made in. Cheap is cheap, though it's unlikely it's America. Still, pleny of junk made right here. I would guess newer wheels are being made thinner to reduce cost. That, and exactly what beenthere mentioned, abuse. These older packers were used by farmers who took care of their stuff.
I am hearing that the breaking has to do with the density of the castings. The old line companies don't use import wheels. Ken Sweet
   / Where do cultipacker wheels come from? #6
Porosity is a problem with cheap castings. I have a guess where many are being made, but it's just speculation. There are some poor foundries here too, and some are cutting prices to get in work. To make money they have to lower quality standards.
   / Where do cultipacker wheels come from? #7
The only new ones I have seen are the ones from Agri-Supply. They look a little weak compared to the 20" Brillion. Any other sources? Can you buy the Brillions as a replacement part for a reasonable fee? The Tuf-Lines look pretty beefy also.
We are a dealer for Brillion and Tufline. These packers are bullit proof. I am sure they will sell individual wheels, however, the cost would be a shocker compared to the wheels on Agri supply. Ken Sweet
   / Where do cultipacker wheels come from? #9
Another excellent example of ''getting what you paid for". Pay nothing, get crap from China that breaks.
   / Where do cultipacker wheels come from? #10
Ken i would just call Agri-supply they are prolly the same as these new "cheaper" lines are using in their equiptment. They are prolly buying from the same importer or from Agri-supply themselves.
I doubt the lady that answers would know the country of origin and tech support would try to skirt the issue. I just may be skeptical :) Ken Sweet
   / Where do cultipacker wheels come from? #12
Well first, you have to have a daddy cultipacker wheel and a mommy cultipacker wheel.............................:laughing:
That is a good one :) Have you ever heard the saying that there is "One in every group" :D Ken Sweet
   / Where do cultipacker wheels come from? #14
I find my cultipacker wheels out in the garden. When the Chinese Cabbage opens up there is a cultipacker wheel!:thumbsup:
   / Where do cultipacker wheels come from? #15
I revitalized a double row Oliver packer last year. It was 8' wide and had a half dozen or more broken wheels on each row. I found that you could cut a chunk of thick wall conduit that had the same ID as the packer wheel holes (1.75 inch shaft) and tack that to the wheel's remaining fragments then fill the wheel with cement. I doubt that there is much "bad" that can happen to the wheels I did that to.
Didn't do all that way for time/cost/bother reasons but more importantly, I didn't think the wood bearings would like the extra 1000# of weight. Still had to cut the axles down some as they were worn to under 1 1/4" in some areas.
8 ft double roller may go way over 1000 #. We ship at 1500 including pallets. Ken Sweet
   / Where do cultipacker wheels come from? #17
I picked up the phone & called agri supply, they told me they bring the cultipacker wheels in from China..if I break one they would replace it, and I would be the first to break one...sounds good to me,will go to Garner store tomorrow...
   / Where do cultipacker wheels come from? #18
I hear reports of some companies that sell used cultipackers that are spreading rumours about imported wheels breaking.
17307 (A55853)
17307 (A55853)
Mini John Deere Truck (A55853)
Mini John Deere...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2381 (A60432)
2381 (A60432)
2020 ASV RT65 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
