8n problems still!
   / 8n problems still!
6 volt also
   / 8n problems still! #12
Do your self a favor, switch to 12 volt and save the 6 volt stuff for a restore or shows.:2cents:
   / 8n problems still! #13
huntnfarm
Glad to hear you are making progress.
Could we get a pic of the wire nest 'after' it has been cleaned up?
   / 8n problems still! #14
yup positive ground. dad cleaned all that crap off and everything else that had crap all gunked up on it. started up and ran...............only ran it for hour or so and no problems yet. we have always had to jump this tractor from when bought it normally. once in awhile it would start on its own but not very often. think a battery tender would be good for it? ill see about getting the harness. thanks again for all your guys help and one of these days well get it figured out:thumbsup:
I'd figure out WHY it has to be jumped.
is it a weak battery? low compression? bad charge system?
forget the bandaids.. go for the stitches....
soundguy
   / 8n problems still! #15
soundguy
I agree. Exactally what I was trying to say.
If you are going to fix it, fix it right.
ill get a picture this weekend when im back up there. we put new wires in that might have been draining the battery. were gonna charge the battery back up and see what happens with that. new battery and we took it back in to test it and everything was ok. ill keep ya'll informed after this weekend
   / 8n problems still! #17
did ya get the wires correct on the vreg?
put a test lamp inline with the bat cable.. if it lights up, there is a draw..
soundguy
   / 8n problems still! #18
My wiring harness on my 8n was a mess...bought a new reproduction. Had to 'excite' the generator to get it to charge. Run ok now.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53473)
2019 Energreen EVO...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
Sterling AT (A53473)
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
