Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
good diagram.
and if one segment of the full wave rectification is out, you can imagine thaqt same diagram with every other positive wave form missing, making the ripple huge.. or average charge voltage less.
depending on the way the regulator works ( much different if perm magnet dynamo ) vs a variable field alternator.. etc.. could even be seeing a dead regulator with a shorted rectifier, and some negative wave form on the battery.. since current output of charge circuit is low compaired to battery, you don't see the negative wave.. just a drop in the positive voltage of the bat.
soundguy
soundguy
