picker77
Gold Member
- Joined
- Feb 4, 2006
- Messages
- 386
- Location
- Central Oklahoma
- Tractor
- JD 3032E, dual remotes, TnT, tooth bar, grapple
I'm having JD's dual rear remote "bundle" installed in a couple of weeks when my dealer gets the $720 kit he ordered from Deere, and I'll be adding CCM's Top 'n Tilt cylinders for these remotes. Someday I will add a grapple and run some hoses up front for it from one of these remotes.
But in reading the CCM website this question popped into my mind about double pilot operated check valves like those that come on the CCM cylinders: Why don't the curl and lift cylinders on FEL's have these from the factory? Seems like it would cure a lot of the minor and sometimes major FEL drift/leakdown problems I read so often about. Are these something that can be installed aftermarket? I've never heard a peep about this subject, so I'm probably overlooking something important here. If so, please educate me. If these things will work on a 3-pt hitch, which has to deal with a lot more weight than an FEL cylinder, why won't they work on FEL's?
