Got Lincoln 255XT for my BD.
   / Got Lincoln 255XT for my BD. #11
I am currently out of home so I can't check. Hopefully I will make it home this weekend and try few more test welds.
I used the setting from the chart inside one of the hinged covers. I am using Praxair 0.045 wire that came with the welder.
I also found that I need to get single power glasses just for the welding. The progressive lense glasses I am normally using have too small viewing angle.
I saw somwhere advertised a "fresnel lense" that is installed inside of the welding helmet.
You'll soon get it sorted out. Almost everything I've built with a few exceptions has been mig welded, with excellent results. A few days experimenting with settings will make a big difference.
I'd suggest increasing and decreasing the voltage setting as you do test passes on a piece of steel. After making several passes, compare each one and see which is the best. I make my own notes on the chart next to their recommended settings. I usually use the wire feed setting Miller recommends on their weld chart, but increase the voltage a bit. No problem doing that with thicker material, as it's less likely to burn through.
The Miller 180 has an "auto-set" position, you dial in the wire size you're using and adjust for metal thickness, the machine does the rest. I have good results using that, but I still like to experiment manually.
Sean
Thanks all for their response. Hopefully I will find time to start some project and report how it went. So far I am very bussy at work. My employer had record last year (I worked about 3500 hours) and this year looks about the same. I have no idea what recession they are taking about on the news.
   / Got Lincoln 255XT for my BD. #13
That's great Ladia. Do some welds with your new beast and take some pictures of the marvelous welds and share them with us. I would really like to get a MIG like you have.
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2017 John Deere 6120E (A53317)
2017 John Deere...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
