Best time of year to plow?
   / Best time of year to plow? #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
We're planning on putting in a vegetable garden at our new home next spring. There's never been a garden there to the best of my knowledge, so the ground is "virginal" as far as plowing is concerned.
I don't have a 3-point tiller and have no plans for one in the next few years. I do have a double bottom plow and will probably either try to find a disc harrow or rent a walk-behind tiller in the spring.
My question is, am I further ahead to turn the soil this fall after the growing season is finished and leave the sods to rot over the winter, or simply plow in the spring a few weeks before I'm ready to plant?
It would seem to me I'm better off to plow in the fall, but there may be something I'm missing.
Your thoughts?
Sean
   / Best time of year to plow? #2
Plow the existing crop under in the fall. Run a heavy drag over it to seal it until early spring, then begin with your disc harrow or tiller. This will give what top growth you have a chance to decompose back into the soil and the ground laying in the rough through winter will catch and hold more snow and rain for the spring/summer crops. Ken Sweet
   / Best time of year to plow? #3
I would add a pass with roundup before plowing this fall, if things are still growing. It will cut back on your weeds next year. We started our vegetable garden with a plowing in the spring and it was definitely a mistake. :ashamed:
-rus-
   / Best time of year to plow? #4
-rus-
Yep, I agree with both (although I have not had much luck with roundup in the fall when things are not growing as fast)...
   / Best time of year to plow? #5
Absolutely plow in fall. The degradation will end soon, due to cold ground temps. Bio action really slows down. You want to do it yesterday.:laughing:
Get it done.
   / Best time of year to plow? #6
There is the sequence on "virgin" sod plowed last fall, to garden this spring. It works!! It's fun. I hope you enjoy it as much as I do.
   / Best time of year to plow? #7
I agree now,also spread manurer ..or when ground frozen so when thawing starts manurer will filter in.
   / Best time of year to plow? #8
Plow now but skip the round up since with a good job of plowing it will be unnecessary. I would also leave it as rough as possible.
   / Best time of year to plow? #9
Totally agree. If you are going to use manure, on the rawer side, you really should put it on now. Raw manure too close to planting isn't a good thing.
   / Best time of year to plow? #10
Plow now, as Duffster says. The frost/thaw cycles will break down clay like nothing else can. Plowed ground will warm much faster in spring too!
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
