How many minutes on this oil?
   / How many minutes on this oil? #1
MrChris
Gold Member
Georgia
Mahindra 3215HST
Just thought I'd share. After warming up the tractor and then changing the oil, I ran it for about 5 minutes and then came back in about 30 minutes to check the oil level. It was showing a tad high on the stick, maybe a 1/4 of an inch over the full hole. Not a lot. Of course being new oil it wasn't as easy to read so I thought I'd check again in the morning. After checking the next morning the level was showing the same. I could have left it be but I thought I'd just drain about a pint into a glass jar. That's the jar on the right!:(
   / How many minutes on this oil? #2
Looks like it has solubilized the soot quite well.
   / How many minutes on this oil? #3
That don't seem right,mine takes many hours to get that dark at dipstick,,[course you got yours from bottom],,what kinda oil,did you drain it real good,and change filter?
   / How many minutes on this oil? #4
Very serious problem. You need to not drive your tractor any more and sell it immediately. Go buy a brand new one with every attachment you need. Wrap it all into 0% financing and make sure to get the insurance to cover it all.
:D:D
   / How many minutes on this oil? #5
Its a deisel, some are dirtier than others but i would say that i would not worry, mine did not get that dirty even after 10 hours of near idle and light work at higher rpms but i may not have the hours you do etc? Deisel will get dirty fast
Motorcraft 15w40. Yes and yes.
That's what I was thinking. Man this oil cleans up my engine quick.;)
   / How many minutes on this oil? #8
If it had been an older 2 stroke Detroit diesel, it would have been jet black in 2 minutes of running. The oil in the crank passageways, and in a few other small spots that do not drain out will easily discolor new oil.
That's why I posted the second pic. The oil on the dipstick does not look that dark. I know when I change the oil annually, that dipstick oil is black.
   / How many minutes on this oil? #10
Well,good thing we ain't got dipsticks on bottom cause we would all change oil twice each time,wouldn't we..
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
UNUSED LANDHONOR ABC-13-125A HYD BRUSH CUTTER (A54757)
UNUSED LANDHONOR...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
