How many minutes on this oil?
   / How many minutes on this oil? #1
MrChris
Gold Member
Georgia
Mahindra 3215HST
Just thought I'd share. After warming up the tractor and then changing the oil, I ran it for about 5 minutes and then came back in about 30 minutes to check the oil level. It was showing a tad high on the stick, maybe a 1/4 of an inch over the full hole. Not a lot. Of course being new oil it wasn't as easy to read so I thought I'd check again in the morning. After checking the next morning the level was showing the same. I could have left it be but I thought I'd just drain about a pint into a glass jar. That's the jar on the right!:(
   / How many minutes on this oil? #2
Looks like it has solubilized the soot quite well.
   / How many minutes on this oil? #3
That don't seem right,mine takes many hours to get that dark at dipstick,,[course you got yours from bottom],,what kinda oil,did you drain it real good,and change filter?
   / How many minutes on this oil? #4
Very serious problem. You need to not drive your tractor any more and sell it immediately. Go buy a brand new one with every attachment you need. Wrap it all into 0% financing and make sure to get the insurance to cover it all.
:D:D
   / How many minutes on this oil? #5
Its a deisel, some are dirtier than others but i would say that i would not worry, mine did not get that dirty even after 10 hours of near idle and light work at higher rpms but i may not have the hours you do etc? Deisel will get dirty fast
Motorcraft 15w40. Yes and yes.
That's what I was thinking. Man this oil cleans up my engine quick.;)
   / How many minutes on this oil? #8
If it had been an older 2 stroke Detroit diesel, it would have been jet black in 2 minutes of running. The oil in the crank passageways, and in a few other small spots that do not drain out will easily discolor new oil.
That's why I posted the second pic. The oil on the dipstick does not look that dark. I know when I change the oil annually, that dipstick oil is black.
   / How many minutes on this oil? #10
Well,good thing we ain't got dipsticks on bottom cause we would all change oil twice each time,wouldn't we..
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2022 PETERBILT 579 TANDEM AXLE SLEEPER (A54607)
2022 PETERBILT 579...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
