New Holland QA same as Kubota?
   / New Holland QA same as Kubota? #1
silverking
Mount Airy N.C.
Grand L 4630/fel
Hi Guys,
Tommorow I'm going to drive a fair ways to get these,...New Holland Forks
The man says they are older off of New Holland, Was there a difference in the QA on this or is it the same as my Kubota QA? Any input would be appreciated.
   / New Holland QA same as Kubota? #2
universal (skid steer) quick attach is universal.
so, if your kuboata is universal QA and the forks are universal QA, then it will fit.
But I can't tell what you have nor what the forks are.
I have the universal type, I'm just not sure about the N/H forks. They look like(from the poor pics) they have the v channel on top but the bottom looks like pin on. I was hoping someone would recognize them and atleast let me know if at worst I could modify them.
I might try anyways for $100.00 and maybe the same in welding it could be worth it.
   / New Holland QA same as Kubota? #4
silverking,
They are NH forks but that style is what many call the 'NH old style' quick attach. They were probably used on a NH L?85 skid steer in the early 90's. Your Kubota is different. Get them at that price and modify to fit your tractor. It shouldn't take much.
This picture might help.
silverking,
Thanks, do you know offhand if the upper v-channel is right, if so I would just need to remove the lower pin receivers and weld on lower tabs.
   / New Holland QA same as Kubota? #6
You can't even buy just forks for that price. Buy it.
   / New Holland QA same as Kubota? #8
You can get weld on plates from eBay for around $115 delivered. I would pick up the forks and weld on one of the eBay plates. You will still be ahead $$$. The cheapest q/a forks new are around $600.
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52128)
J and L Cargo...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
