White Pine needles!!!
   / White Pine needles!!! #1
Jabroni
Central MA
Kubota BX24
My arms are about to fall off from hand raking white pine needles. I must have raked several cubic yards of needles today. There has to be a better way. I hand raked the area once creating many small piles of needles, then raked them into my loader. Afterwards, I kind of scoured the lawn with the rake to bring any stragglers to the the surface, then ran over them with the mower deck and a power bagger to suck them off the lawn. I'd like to find a 3pt rake with lots of wire tines that I could drag around to bring the matted needles to the top of the grass but wouldn't damage the lawn itself. Does an implement like that exist? Suggestions eagerly accepted!
   / White Pine needles!!! #3
   / White Pine needles!!! #4
Get a tow behind lawn vac - Trac Vac, Cyclone Rake etc.. They do a good job without the raking effort. We have pines and last year they shed like crazy this year not so bad - but the trac vac I have does a good job on them and them they go to the compost pile.
   / White Pine needles!!! #6
They can have all of mine they want. It's probably not profitable for the small landowner. I'm down to less than 50 trees from an original 500, and I don't miss them one bit.
Thanks, but no thanks. I've got 40+ acres of loblolly pine plantation. Prior to my retirement, I gave some thought to starting a pine-straw enterprise following retirement. After some research and pencil pushing, I abandoned the idea. I didn't have enough acreage, longleaf and slash pine needles are preferred, and most importantly, it seemed too much like work.:)
Steve
   / White Pine needles!!! #7
I've got a dozen white pine, and love them all. Even have planted a half dozen new ones. To each his own.
I don't do much of anything with the straw. In spring, we'll rake it back under the dew lines of the tree and use some of the excess as mulch around new Maples, Ash, Chestnuts, Aspen, etc that we also have planted. Two or three for each grandkid. They all know which is theirs and one day, they'll tell their kids about these tall, shady trees that their old papa planted. :thumbsup:
   / White Pine needles!!! #8
I have a couple hundred 45 yr old white pine and same number red pine. I let the needles compost back into the ground. Some get picked up when I pick up leaves with the Deere powerflo and MC 519 cart. But that is incidental to cleaning up leaves which I don't let compost.
   / White Pine needles!!! #9
There is nothing any more beautiful than a mature White Pine. The city of Chicago was practically built from the wonderful lumber of the highly sought after White Pine. I have a few around to tend to also. The needles shed always manage to find a home nestled amongst my shingles and that is the part I hate.
The clear timber from a White pine has provided many a door jamb or molding. Not only good for door jambs it makes a fine 2 X 4 also. Rarely does White Pine Lumber twist and it holds a nail very well.
Recenty I took an a couple old straight White Pines down for threatening my house. No more pine needles to contend with and I got 200 2" X 4" X 8' studs and built a garage framed of the wood. I manged to have 100 left so I gave them to he neighbor and he built another garage.
rimshot
   / White Pine needles!!! #10
We have alot of white pine. I like them. The needles dont seem to accumulate on the lawn much. I just mow normally with a JD mulching deck and they disappear. The pine cones are a much bigger pain. I usually pick them up by hand each spring. The really bad thing though is the pine needles in my truck heater vents and the pitch on the truck paint. Not to mention all the pollen that blows into the house.
   / White Pine needles!!! #11
I use two or three 5 gal buckets full of pine needles a year in my bee smoker:D
Get a tow behind lawn vac - Trac Vac, Cyclone Rake etc...
Hi Carl. I owned a 'Rake for several seasons, and while it did a great job with surface needles, once they got down into the grass, I found they matted up and nothing had the power to lift them up. I'm going to investigate the pinestraw rake further. Thanks!
   / White Pine needles!!! #13
I got my masters dabbling with some figures on pine straw for privite landowners in the south that had longleaf pine. Its the perffered straw, the color is better and they retain it as a mulch longer than lobs. They also last longer and dont break as easily. Around here you may not be able to sell the straw from under 50 longleafs (i probly could , but i sell the stuff as part of my job so i have more contacts than the normal person) but you sure could give it away to the right people who will come rake it remove all the fresh straw and pile all the little sticks and cones in a pile.
   / White Pine needles!!! #15
Don't listen to these naysayers. Pine trees suck. These guys must be thinking of firs or something. I can't think of a single good thing to say about pine trees - they kill everything else, they're ugly as heck, drip sap all over everything, turn the entire region yellow once a year, AND they drop a billion needles all over everywhere. I just raked up a bunch needles myself this weekend. Yuck.
You need one of these (so do I):
Harper Goossen Debris Blowers
JayC
   / White Pine needles!!! #16
It's bad enough having to deal with pine needles on the ground, but if a car is left outside they fall all into nooks and cranny's and are frustrating to clean out.
I don't have enough pines to make a business of pine needles, but enough to make you come up with dirty words for them. On top of that pines aren't very strong trees. Lots of problems come from having them too close to the house.
My $0.02,
   / White Pine needles!!! #17
JayC
I would not want a pine over my parkin area (oaks can be just as bad with the fine sap) or near where an ice storm can break big limbs off or blow on on my house but i love pine trees. I make my living off of harvesting them and so do many other people across the south. Its out larges industry in this state, with out it we would probably be missing 20-30% of our economy (SC that is).
   / White Pine needles!!! #18
Don't forget that the dam things blow down with a stiff breeze. I had 20 or so come down during the wind storm this year. Oaks and Maples stood strong, but the pines were all over the place, what a mess.
   / White Pine needles!!! #19
Pine trees have there places,close to your house is not one of them,,but for that matter it ain't a good place for many trees,,if it wern't for pine trees I would not only have to listen to my neighbor,,I would have to look at him too.:D
   / White Pine needles!!! #20
I can see that I'm out numbered here but I kind of like our home in the pines.
405 (A52706)
405 (A52706)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
22FT Roadway Dry Van Pup Trailer (A56438)
22FT Roadway Dry...
Towable Centrifugal Water Pump (A59228)
Towable...
