How do I tell which model?
   / How do I tell which model? #1
SupplySergeant
Harrodsburg, KY
'39 Ford 9N
I just brough my new baby home, the guy I bought her from thought it was a 1947 8N. It has a 3 speed tranny, the 3-point lever is on the right, and the pto lever on the left. I think I have a 9N, or maybe early 2N. But I admit I don't know that much about tractors, in general. As soon as I figure out how, I'll post pictures.:thumbsup:
I figured it out! How to post pics, that is.
   / How do I tell which model? #2
it is a 9n and somebody has changed the front hubs on it and changed the front wheels and tires
Thanks! Everything works smoothly, except the brakes. Since I live on hills, I plan to replace the brakes ASAP, and needed to verify the model to order them. Anyone know the best place to get them?
I finally found the serial number. *9N26791* The chart I found says this is a 1940 9N. For a 70 tear old tractor, she runs great! Fires right up (as long as I remember to open the fuel cutoff), shifts into all three gears, three-point goes up and down just fine. The guy I bought her from had a two-bottom moldboard plow on her, and we stood two big countryt boys on the plow, the three-point picked it right up. PTO still has the screw-on cover, and I don't see any wear on the splines. Only problem is the brakes, and I ordered a brake parts set and pads ftom YTM last night. Does anyone know if there is a decent ROPS available for the old girl?
   / How do I tell which model? #5
The best source of info I've ever found for the old Fords is Ntractorclub.com. Anything you'll ever want to know about those N series tractors will be found there. It's truly one of the best and most useful web sights I've ever seen-with all due respect to TBN.
   / How do I tell which model? #7
i-beam radius rods and all.
soundguy
soundguy
Soundguy, I've noticed you seem to be one of the resident experts. I'm sure I'm showing my ignorance, but was the a problem with the I-beam radius rods? I plan to keep the old girl for a long time, so I'd like to repair/rebuild anything likely to break on me. I only have a 2.5 acre lot, mostly wooded, so the 9N is a big toy, but I'd rather not roll down a hill sideways!
   / How do I tell which model? #9
no the ibeam radius rods or the orginal rods for a 9n the 2n and 8n's had tube type i would think the ibeam style would te stronger but cost more to make so the quit using them
Sounds about right. I used to be a drop-forge tooling diesinker, we made a few i-beam front end dies, but fewer each year.
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
CASE 621G (A53843)
CASE 621G (A53843)
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
