How do I tell which model?
   / How do I tell which model? #11
Soundguy, I've noticed you seem to be one of the resident experts. I'm sure I'm showing my ignorance, but was the a problem with the I-beam radius rods? I plan to keep the old girl for a long time, so I'd like to repair/rebuild anything likely to break on me. I only have a 2.5 acre lot, mostly wooded, so the 9N is a big toy, but I'd rather not roll down a hill sideways!
no they are fine.. easier to fix when damaged too, imho.
I merely commented on them as there are plenty of year to year changes on the 9n/2n, and you can use those to date a tractor even if it doesn't have a viable engine serial number.. the ibeams are correct for your model.. etc.
soundguy
Cool, thanks! My plans are to use this tractor, not restore it, but when it doesn't have a negative effect on operation, I'd like to keep it original. Am I correct in believing she should be all dark gray?
   / How do I tell which model? #13
yep.. some call it battleship grey.. however when i painted my 46' 2n.. I actually used ferguson grey.. and it looked great.
soundguy
   / How do I tell which model? #14
soundguy
Rumor has it, with war looming in Europe, Henry Ford could get a great deal on train car loads of battleship gray/gloss paint. I just throw that one out. I used rustoleum gray on mine. Color blind guy said it was perfect.
That sounds about right, Henry was a well known skinflint!
My brake parts came in today, so I pulled Ol' Rusty in the garage to start the job. Slid my 3-ton jackstands under the axles, then realized that they were three inches short of hitting the axles BEFORE I jacked the tractor up! Now I'm waiting on my new 12-ton stands to come in.
   / How do I tell which model? #16
yep.. went to use my 5 ton jack stands on my 950 rowcrop then realized due to the high ground clearance.. they came real close too!
soundguy
The 12-tons I just ordered are supposed to go to 30 inches, so I think I'm good to go on a 9N, dont know about that 950, it looks a lot taller!
   / How do I tell which model? #18
quite a bit taller.. maybee 2x as much..
soundguy
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
Galvanized Livestock Gates - 4FT x 18FT (2x Gates) (A55218)
Galvanized...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2009 Kenworth T800 Tri-Axle Day Cab Wet Kit Truck Tractor (A52377)
2009 Kenworth T800...
