Help please to drain fuel tank
   / Help please to drain fuel tank #1
joesb1
kubota bx2660
I made a mistake and add gasoline to my diesel fuel Kubota BX2660 tractor. How can I drain fuel?
   / Help please to drain fuel tank #2
Under your tractor, toward the rear, you will find an in-line fuel filter.
I'd simply take that off and let gravity do it's job. Hopefully, you caught your mistake before turning on the key, or running it?
   / Help please to drain fuel tank #3
You should look near your HST white cooling fan. The in-line filter is white, clear and easy to spot. The quarters are a bit cramped, but you can do it.
   / Help please to drain fuel tank #4
Hello and welcome to TBN
Also, you may want to post your Kubota questions in the Kubota section where more members may see it
bpfick is good for info like always , but you may get more views in the Kubota section
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
Kubota RTV500 (A47384)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
