Oil Pressure Sender Unit, how much OHMs
   / Oil Pressure Sender Unit, how much OHMs #1
Nuno
Northern Germany, near Hamburg
Jinma 244E 2009
Hey,
i have to replace my Oil Pressure Sender Unit and i am looking for an After market Sender Unit but i have no informations about the OHM Range of the OEM Sender Unit so i hope any of you Guys can help and tell me how much it is
Thank you
   / Oil Pressure Sender Unit, how much OHMs #2
If you're going aftermarket, why not get a mechanical gauge instead? Going to another electrical gauge is really just a giant step sideways. Several guys here have done so, and I'm pretty sure they even ID'd what and where they got the hardware. If nobody chimes in, I'm thinking a little work with the site search engine should come up with the (mechanical gauge) info
//greg//
   / Oil Pressure Sender Unit, how much OHMs #3
I got a sending unit at Auto Zone when I knocked mine off years ago. My gauge still works fine but in the mean time I installed a cheap $10 mechanical gauge I got at Harbor Freight or WalMart. Can not remember but it came with a bunch of adapters and one fit fine.
Chris
Hey Greg and Chris,
thank you for reply.
the reason why i am looking for an new Sender Unit is that i would continue to use the Pressure Gauge in the Dash.
I have no single Pressure Gauge an no room to install one
only place where the part between the Engine Stop and the Ignition Switch but there it is uncomfortable for me to read the Gauge when i am oparating the Tractor,
so i am thinking to buy an Sender Unit that will be compatible to the Pressure Gauge in the Dashboard.
VDO is very common Brand over here in Germany and if you will buy one you can Chose of various thread connections, Pressure Ranges and Ohm Ranges, thats why i need to know the Ohm Range of the OEM Sender Unit
   / Oil Pressure Sender Unit, how much OHMs #5
Just call Tommy or Ronald and get a oem one then. They are cheap and both have dirt cheap shipping plus you will have it by next week if ordered today.
Chris
   / Oil Pressure Sender Unit, how much OHMs #6
Well, the data you seek is not something not readily available from the Chinese. Obtaining it would involve a time-consuming process of some individual actually testing his across the extremes of ambient temperature and oil temperature. I don't think it's worth the time, and therefore second the recommendation to simply go to your Hamburg Jinma dealer for an OEM replacement.
//greg//
this would be nice to have a Jinma Dealer in Hamburg but,
there is only "ONE"
Jinma Dealer in Germany that have Spare Parts and it is not an official Jinma Dealer or Importer and he takes longer to answer an Email or PhoneCall as Tommy needs to send Parts to Germany.
There are a few more Dealers that sell only crated Jinma tractors, they offer also Spare Parts and Warranty but only on the Paper.
One More Jinma Dealer in Austria but this Dealer is so expensive that it worth to enter one of these cheap Last Minute Flys to Shanghai and buy it over there, for sure!
ok, maybe i will order one from Tommy and use them after checking the OHM Range and if the Sender Unit one day will fail or quit his work i can upgrade to an better one.
Chris
Hey Chris,
yes thats right,
my last order from Tommy takes only 5 days to my door and maybe i will order one from him.
1264 (A50490)
1264 (A50490)
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
