Serial number TC24?
   / Serial number TC24? #1
pekabu
NH
TC24D
I can't find my owners manual right now, and everytime I get to where my tractor is it's dark and raining. Anyone know where the serial number is on this model? I assume its on a plate on the left side, but...
Thanks
Dave
   / Serial number TC24? #2
All I have seen are on a plate up under the left operator's platform on the clutch/transmission case right behind the engine.
   / Serial number TC24? #3
is NH still puting them aft of the starter? on the bellhousing.... my 02 7610s is like that. pretty standard from about mid 1953 at least til 02 that I know of.
soundguy
   / Serial number TC24? #4
Soundguy, I think that method of marking may be on larger tractors, but I believe all Shibaura engine TCs are marked on the transmission case on the left side under the operator platform. Perhaps Shibaura doesn't know the tractor serial number when the engine is manufactured and it's easier for NH to assign it and label it in a different spot.
   / Serial number TC24? #5
sounds reeasonable.
soundguy
So I finally found it. Right hand side, on the inside of the front bumper frame all the way forward. It's not mounted on the engine or tranny.
   / Serial number TC24? #7
leave it to NH to change something that's been good since 1953.. :)
soundguy
   / Serial number TC24? #9
Holy Smokes! On the INSIDE of the bumper frame? Did you have to knock on a door, say the magic word three times, and use your decoder ring? :rolleyes:
   / Serial number TC24? #10
what.. the underside of the rear end wasn't available for someone to lay on a creeper and hand stamp them upside down?
soundguy
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
