Re: I'm wondering if my little 125 LINCOLN 120 volt will weld 1/4" stock to 1/8 "
On a mig,the wire speed is the amps,you set the voltage and match the amps to that[or match your voltage to wire speed],course machines vary in the way the amps and volts are set,,but you got to match your wire size to amps/volts to get it to run right,little 110[never used one],but bet you would have to turn voltage way up and match wire speed to that to weld on thicker stuff.[you need to turn both down for thinner stuff]
Bare wire mig with co2 shielding if I remember right is about 120 amps and 19 volts with .035 wire.Reason I know is bigger machines have amp and volt gages,some of the littler ones,don't believe do.
Course you got to be able to control the puddle,so you can only burn so hot to do this,if you are welding out of flat postion,you will see what I mean,but flat you can burn pretty hot unless your on real thin stuff.
Brands of welders are like brands of cars except you ain't got that many good ones to chose from,whatever brand you got,if it works right,than its the right brand
