New FEL Bucket
   / New FEL Bucket #1
kendive
Bought a used B7510 with an LA302 FEL and the Bucket is a little bent up and rusted. So I decided to get a new one with hooks welded on and trying to decide what to do with the old bucket...
Sell it, Keep it.
Ideas?
   / New FEL Bucket #2
I had the same issue with my B7500 . I just recently had some hooks welded on the beat up bucket and am going to use it for lifting and any stone work that might ding up the new bucket .
My beat up bucket was damaged by the previous owner with a set of bolt on forks and a pallet of firewood that got away from him
   / New FEL Bucket
So it's pretty easy to swap the bucket out? I know there are pins holding it in place but not sure if they had to be pressed out.
   / New FEL Bucket #4
No they don't need to be pressed out . I did replace the cotter pins with the with the hairpin style for easier removal .
   / New FEL Bucket
Ok thanks... That's a good idea.
   / New FEL Bucket #6
Here is a photo of the hooks I had welded on . I went over them with a can a primer and kubota paint from Tractor supply .
   / New FEL Bucket #7
Sell it, Keep it.
Ideas?
Here is what I did with one in similar condition. Cut off the bad part, built a ridgid framework to support the upper wooden part that is removable as I have yet unrealized plans for another bolt on apparatus. Use this to bring in boiler wood in the winter and minor snow removal.
   / New FEL Bucket #8
Where you did you get the new bucket? Did you pay dealer prices?
   / New FEL Bucket
Yes I went to the dealer. It was 277 for the bucket and then 70 for freight. They are going to installed for free and then I am having them weld a couple of hooks on the new one for me.
I took it to the dealer where it was bought originally. The person i bought it from got it there new in 05.
I also am having them service the transmission. Change the fluid and filter. It only has 276 hours on it but I just like to know all the fluids have been changed. I did the Engine oil, Fuel filter, and Radiator fluid myself.
   / New FEL Bucket #10
Based on where I live which Is rock country I'd make a rock bucket out of the old bucket
Joel
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
