Thread Sealant (with Teflon) for my hydraulic connection
   / Thread Sealant (with Teflon) for my hydraulic connection #1
ampa
Gold Member
I'm just double checkin' before hand....I read something about Teflon tape bein' a no no...the stuff I bought is in liquid form but contains Teflon....I just need to make sure it's okay to use....I did ask the hydraulic supply for something to put on the pipe thread fittings..."O" rings are used on the other parts...I bought two new "O" rings for the tractor connection side housing... just makin' certain there are no leaks....that's about all I need to know....Thanks in advance....take care....Ampa <>:)
   / Thread Sealant (with Teflon) for my hydraulic connection #2
I know people will not agree, tape works also. IF YOU KNOW HOW to put tape on and leave first thread showing with out tape, how are all these people getting the tape in the hydraulic system????? The compound should work just fine, of course if compound does not end up in hydraulic fluid.
   / Thread Sealant (with Teflon) for my hydraulic connection #3
I learned that teflon won't hold up to hydraulic fluid, I used the tape and it ate it apart. I talked with a hydraulic repair shop and a few others, now I use permatex and have never had an issue. You do need to be carefull and just apply on threads.
   / Thread Sealant (with Teflon) for my hydraulic connection #4
All of my tractor fittings are done with teflon tape - existing, that is. I asked the guy at the hydraulic supply shop counter if fittings were supposed to be just like NPT water plumbing (teflon tape on the male threads, then hand tight + 1 turn) - he said yes.
I'm very interested in this discussion, since I will be putting my new system together this weekend and next. I was planning on using plain 'ole teflon tape, but it there is something better, I'd like to hear it. I've not had great luck with just pipe dope, however. I've never had a leak with just tape, and now I usually use both tape (M) and dope (F) on NPT fittings for water.
JayC
   / Thread Sealant (with Teflon) for my hydraulic connection #5
Teflon tape, occasionally will swell, causing weak castings to crack. Teflon paste doesn't seem to do this. Loctite 545 hydraulic/pneumatic sealant works real well, locks parts in place, and won't contaminate systems.
   / Thread Sealant (with Teflon) for my hydraulic connection #6
You are supposed to use a paste, NOT tape on hydraulic fittings. A PTFE based past is best like Loctite #565 or Permatex 80632. DHH also sells a off-brand.
   / Thread Sealant (with Teflon) for my hydraulic connection #7
JayC
Just wondering who this is in our area giving out this info......:confused:
   / Thread Sealant (with Teflon) for my hydraulic connection #8
:thumbsup:......Teflon Tape in Hyd Systems makes lots of trouble......why would anybody chance it with the cost of repairs/troubleshooting.....(although great for the Hyd Shop).......Is Teflon Tape Better?.....No.....Pipe fittings are interference fit , the tape or paste is only a lubricant to minimize galling .....Ever notice when you use pipe threads over and over again they seam to leak, Pipe Threads were never meant to be used more than once......
Years ago at a Motion Industries Hydraulic Seminar the instructor mentioned in Alabama at the main headquarters they used to sell Teflon Tape cheap and snicker when someone bought it......
   / Thread Sealant (with Teflon) for my hydraulic connection #9
Unfortunately, it does not matter what you say, or that you are and expert in this field...others will still argue that it's fine to use tape and that by leaving the first thread or two tapeless is the answer.
One problem I think is the proper paste is expensive, and people see the .97 cent tape at Home Cheapot and succumb to frugality. As you know-nothing is cheap when it comes to hydraulics except O-rings and advice here on TBN.
Thanks for the backup;)
   / Thread Sealant (with Teflon) for my hydraulic connection #10
Teflon tape can clog filters and do other damage in close tolerance components. I had one bad experience many years back and will not use it again. Kennyd has it right.
air compressor (A55758)
air compressor...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2006 APPA TL (A55788)
