New Holland TN65S error/fault code problems
   / New Holland TN65S error/fault code problems #1
JohnM575
New Holland TN65S
Hi there,
I am asking a question on behalf of my father. We have had a few error codes problems in which we have solved , but are stuck on error code 14 for a TN65s.
I understand the manuals will have a full list of the codes, but is there a link someone may be able to shoot my way to view a full list?
Thanks in advance.
   / New Holland TN65S error/fault code problems #2
Hi there,
Thanks in advance.
No. If you want the full list, you have to pony up unless someone will send you a pirated document. The manual also has detailed troubleshooting. If you don't want to buy the complete manual set, buy the transmission section. That has what you need.
Choose Items
Fault 14 is gear shift switch signal voltage shorted to 5V or 12V. That's the gear shifter, not the range shifter.
Cheers for the quick reply Rick.
I will let you know how we get on, our mechanic was wondering the code error as we just purchased the tractor and do not have any manuals for it at this stage.
Lets hope its a quick and easy fix!
2006 Sterling Acterra Rollback Wrecker Truck (A59814)
2006 Sterling...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
Ford F-250 Bed (A57453)
Ford F-250 Bed...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2017 Snorkel S4732 Scissor Lift (A57453)
2017 Snorkel S4732...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
