Oct 28, 2010 / Where is the model number on a Fred Cain 10' Rotary Cutter #1 J Joel888 New member Joined Oct 28, 2010 Messages 17 Tractor Many Anyone know where the model number is located on a Fred Cain 10 ft rotary cutter? thanks for any help.
Oct 29, 2010 / Where is the model number on a Fred Cain 10' Rotary Cutter #2 sweettractors Advertiser Joined Jul 19, 2003 Messages 7,318 Location Central Kentucky Tractor JD 6403 CHA-JD 3130 CHA I don't recall a tag being on those. It would either be pull or 3 point? If you need parts, we can help. Ken Sweet
Oct 29, 2010 / Where is the model number on a Fred Cain 10' Rotary Cutter Thread Starter #3 OP J Joel888 New member Joined Oct 28, 2010 Messages 17 Tractor Many what i am in need of is the tail wheel yoke... it has a 1.5" dia shaft.
Oct 29, 2010 / Where is the model number on a Fred Cain 10' Rotary Cutter #4 sweettractors Advertiser Joined Jul 19, 2003 Messages 7,318 Location Central Kentucky Tractor JD 6403 CHA-JD 3130 CHA Joel888 said: what i am in need of is the tail wheel yoke... it has a 1.5" dia shaft. Click to expand... The tail wheel fork with 1 1/2 inch stem and 1 inch axle bolt and is it pull type or 3 point type? Ken Sweet
Oct 29, 2010 / Where is the model number on a Fred Cain 10' Rotary Cutter Thread Starter #5 OP J Joel888 New member Joined Oct 28, 2010 Messages 17 Tractor Many 3 pt hitch that is set up to use as a semi mount.
Oct 29, 2010 / Where is the model number on a Fred Cain 10' Rotary Cutter #6 sweettractors Advertiser Joined Jul 19, 2003 Messages 7,318 Location Central Kentucky Tractor JD 6403 CHA-JD 3130 CHA Joel888 said: 3 pt hitch that is set up to use as a semi mount. Click to expand... Cost of Tail wheel Fork for a 10 ft Fred Cain with 3 point and 1 1/2 inch stem and 1 inch axle hole is $89 + UPS. Ken Sweet
